supraGZaerotop Posted March 23, 2012 Share Posted March 23, 2012 hi all, supras booked in for a big service, bought a few parts, silkolene pros 5w 40 silkolene sync 5 for the diff toyota atf fluid oil filter air filter fuel filter sump plug washer both cam cover breathers cambelt cambelt idler cambelt Tensioner (havint got plugs cause the iridiums in there have only done 14k, brakefluid and toyota red coolent has been done in last serivce, so i dont see the point in doing that aswel) anything you guys recommend i change, car has just nudged 100k Link to comment Share on other sites More sharing options...
slugger1 Posted March 23, 2012 Share Posted March 23, 2012 I think I had a test drive in this a year or so ago. Did you buy it from a bloke in Windsor? If it is the one I'm thinking of it was a very nice drive! Link to comment Share on other sites More sharing options...
AndyT Posted March 23, 2012 Share Posted March 23, 2012 (edited) Crank pulley. Been a couple let go this last year. Not pretty. Unfortunately a little pricey but less so than the alternative. Brake fluid? Pads? If jspec then CW fast road pads or Porterfields. Worth getting braided hose and a master cylinder brace too. Edited March 23, 2012 by AndyT (see edit history) Link to comment Share on other sites More sharing options...
Nic Posted March 23, 2012 Share Posted March 23, 2012 Worth checking the oxygen sensor whilst you're at it, see HERE Link to comment Share on other sites More sharing options...
supraGZaerotop Posted March 25, 2012 Author Share Posted March 25, 2012 hi, been done already by previous ownerCrank pulley. Been a couple let go this last year. Not pretty. Unfortunately a little pricey but less so than the alternative. Brake fluid? Pads? If jspec then CW fast road pads or Porterfields. Worth getting braided hose and a master cylinder brace too. Link to comment Share on other sites More sharing options...
supraGZaerotop Posted March 25, 2012 Author Share Posted March 25, 2012 also been done changed for a brand new one, thanks for the infoWorth checking the oxygen sensor whilst you're at it, see HERE Link to comment Share on other sites More sharing options...
supraGZaerotop Posted March 25, 2012 Author Share Posted March 25, 2012 um, not sure. i bought it from reading if that helps, previous owner was a guy on here called dilocruzyI think I had a test drive in this a year or so ago. Did you buy it from a bloke in Windsor? If it is the one I'm thinking of it was a very nice drive! Link to comment Share on other sites More sharing options...
tomgeer Posted March 25, 2012 Share Posted March 25, 2012 You could also do the brake fluid, auxiliary belt and coilpack connector clips? Link to comment Share on other sites More sharing options...
slugger1 Posted March 25, 2012 Share Posted March 25, 2012 um, not sure. i bought it from reading if that helps, previous owner was a guy on here called dilocruzy Yes that's the one. Link to comment Share on other sites More sharing options...
supraGZaerotop Posted April 3, 2012 Author Share Posted April 3, 2012 really, well yeah then i guess it is, yeah its a nice car, previous owner has spent alot of coin on it, folder 2inches thick Yes that's the one. Link to comment Share on other sites More sharing options...
supraGZaerotop Posted April 3, 2012 Author Share Posted April 3, 2012 i know the aux belts been done, coilpack connectors, yeah maybe il do that, thanks mateYou could also do the brake fluid, auxiliary belt and coilpack connector clips? Link to comment Share on other sites More sharing options...
supraGZaerotop Posted April 6, 2012 Author Share Posted April 6, 2012 had the car back yesterday, OMG feels nice auto fluid change, diff oil change, all filters, and cambelt and both tensioner and idler. feels smooth Link to comment Share on other sites More sharing options...
