LOGIE Posted March 23, 2012 Share Posted March 23, 2012 Ok so im another one doing the NA-TT convertion que the yawns, at the minute i have my eye on a TT engine for sale its off an Auto car and its a VVTI it comes with a wiring loom and an ECU and its for sale for £1000, the seller doesn't know about the milage and the ad is very vague. So my question(s) is...? Is there a down side to owning a VVTI engine as opposed to older engine? Is this priced well? Also is there any way you can tell an Aristo lump from a Supra one? Many thanks for your patience on my very amateur questions. Link to comment Share on other sites More sharing options...
alex2jz Posted March 23, 2012 Share Posted March 23, 2012 Fitting a VVTI 2JZ-GTE in a non-VVTI Supra and making everything run as it should requires a lot of work. Also, it is easier to modify a non-VVTi 2JZ. The Aristo lump has a front oil sump and is much more common, whilst the Supra lump has a rear oil sump and it's harder to get. Link to comment Share on other sites More sharing options...
LOGIE Posted March 23, 2012 Author Share Posted March 23, 2012 Fitting a VVTI 2JZ-GTE in a non-VVTI Supra and making everything run as it should requires a lot of work. Also, it is easier to modify a non-VVTi 2JZ. The Aristo lump has a front oil sump and is much more common, whilst the Supra lump has a rear oil sump and it's harder to get. thanks alex, so is it possible to buy an aristo engine then buy a supra sump and fit it? Link to comment Share on other sites More sharing options...
alex2jz Posted March 24, 2012 Share Posted March 24, 2012 thanks alex, so is it possible to buy an aristo engine then buy a supra sump and fit it? A shop in Hungary already has a modified sump that replaces the stock Aristo sump and converts it into a Supra one. Copy paste this into the search box on the website : Toyota Supra MK4 2JZ-GTE 2JZ-GE hátul összefolyós komplett olajteknő (házilag átalakított) http://www.tuningaruhaz.hu/site/site_main.php?id_horizontal_menu=1 I have the same problem, i find only Aristo 2JZ's for sale ... Link to comment Share on other sites More sharing options...
