jmcc42uk Posted March 22, 2012 Share Posted March 22, 2012 Hi Guys, Just gone BPU and trying to dial in the correct settings on my boost controller. I have a SARD Trigger EBC and when the boost is set to 1.0 bar I am seeing a peak of 1.14. Then when set to the high boost setting of 1.05 the peak went up to 1.38. The gain control is set to zero. When the boost peaks, it's only there for a second and then starts to come down. Is it dangerous to peak at 1.4 for a second on the j-spec turbos? Would really like it to boost 1.2 and hold that level. Thanks Jon Link to comment Share on other sites More sharing options...
Robzki Posted March 22, 2012 Share Posted March 22, 2012 Do you have a restrictor ring installed? Link to comment Share on other sites More sharing options...
jmcc42uk Posted March 23, 2012 Author Share Posted March 23, 2012 Yep. got it from whifbitz. The car naturally boosts to 1.14 with the boost controller off Link to comment Share on other sites More sharing options...
CJ Posted March 23, 2012 Share Posted March 23, 2012 IMHO restrictor rings are a complete waste of money and rarely (if ever) work properly. Link to comment Share on other sites More sharing options...
mellonman Posted March 23, 2012 Share Posted March 23, 2012 im unsure if this is the same as the avcr but you need to turn the duty down to stop the over boost this probably happens when changing gear boost spike is a NO NO i have lost a set of hybrids to that lol, very messy Link to comment Share on other sites More sharing options...
jmcc42uk Posted March 23, 2012 Author Share Posted March 23, 2012 Yeah. Ive peaked at 1.4 bar twice so far. will this have done any damage? The gain control is turned all the way down but at 1.0 bar the spike is 1.14 then 1.05 the spike is 1.38. Can't work out why it's spiking so hard if the gain is at 0. Link to comment Share on other sites More sharing options...
Robzki Posted March 23, 2012 Share Posted March 23, 2012 IMHO restrictor rings are a complete waste of money and rarely (if ever) work properly. Is there another way to keep the jspec turbos in one piece, I am genuinely interested as I don't have a restrictor ring but do have a sard cat, but this doesn't have enough back pressure as I've hit 1.4-1.5 a couple of times and I now drive like an old man until I get a RR. Link to comment Share on other sites More sharing options...
mellonman Posted March 23, 2012 Share Posted March 23, 2012 does it not have break points where you can adjust what boost you want at what rpm, watch where you over booost the compensate with dialing a lower boost setting, what boost do you make with is off Link to comment Share on other sites More sharing options...
jmcc42uk Posted March 23, 2012 Author Share Posted March 23, 2012 Its makes 1.14 peak with the controller off Link to comment Share on other sites More sharing options...
CJ Posted March 23, 2012 Share Posted March 23, 2012 Is there another way to keep the jspec turbos in one piece, I am genuinely interested as I don't have a restrictor ring but do have a sard cat, but this doesn't have enough back pressure as I've hit 1.4-1.5 a couple of times and I now drive like an old man until I get a RR. As soon as you raise the boost from stock, there is a danger they can go pop - and that is the same for UK as well as J-specs. I remember asking the question years ago as to why my turbos boosted to 1.x (I cannot remember the exact figure but it was high) despite my boost controller being turned off and a restrictor ring being fitted. Nobody could answer. Link to comment Share on other sites More sharing options...
mellonman Posted March 23, 2012 Share Posted March 23, 2012 1.14 i wouldnt even bother witha boost controller , the thing is they dont normally work until 20% i know with the avcr anyway, you will have to get your boost down by the mean of a smaller rr or see what you can do with the brake points i wish i could help you more but i dont know that unit, maybe search on google Link to comment Share on other sites More sharing options...
jmcc42uk Posted March 23, 2012 Author Share Posted March 23, 2012 Its a Sard Trigger. cant post a link on my phone. scott m had one i think Link to comment Share on other sites More sharing options...
mellonman Posted March 23, 2012 Share Posted March 23, 2012 like i said i dont know anything about it maybe pm scott he might be able to help but i would wait a couple of minutes his in a bad mood Link to comment Share on other sites More sharing options...
