Oil dribble from stock BOV onto heatshield and bad mpg
Iky
Which sensor do you mean, the one at the bottom of the rad?
/QUOTE]
No, there are 2 sensors in the alloy neck bit that comes off the water pump. Under the upper radiator hose engine side.
The one with two wires is the one to check. The other one with one wire is just for the guage in the speedo.
Edited by Iky (see edit history)
Thank you, just had a look and iv seen it I will test it tonight useing the manual for guidance
