2jzEd Posted March 22, 2012 Share Posted March 22, 2012 Like the title says i started noticing drips of oil. Took the No1 and No2 timing belt covers off and stuck a flashlight in there to see oil coming from around the oil relief valve bolt/nut. What's the best move i have already gotten the part numbers to order the parts that comprise of the relief valve i.e springs and o-ring etc. Is this a quick fix or should i replace my oil pump instead? Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 22, 2012 Share Posted March 22, 2012 Unless someone has over tightened the cap and cracked the pump housing (quite common....) a new O ring should fix it. Link to comment Share on other sites More sharing options...
2jzEd Posted March 22, 2012 Author Share Posted March 22, 2012 Quick question on this. Can i Operate without removing the crank pulley? Link to comment Share on other sites More sharing options...
2jzEd Posted March 26, 2012 Author Share Posted March 26, 2012 Bump Link to comment Share on other sites More sharing options...
Andy Blyth Posted March 26, 2012 Share Posted March 26, 2012 Just by looking at your photo, I'd say no. You're going to need to remove the water pump to undo the cap on the relief valve which means removing the cam belt and hence the crank pulley. Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 26, 2012 Share Posted March 26, 2012 Sorry, only just seen this. You need to remove the crank damper, and from memory, the water pump, too, but not 100% on whether there's enough clearance to get the cap off with the water pump still in situ. Getting the cap back on can be awkward, you need strong fingers as the relief valve spring is long and powerful. DO NOT cross thread it!! As the cam belt looks new there should be no problem getting the damper off. Link to comment Share on other sites More sharing options...
2jzEd Posted March 26, 2012 Author Share Posted March 26, 2012 Thx alot guys i'm just waiting on the parts to arrive. Link to comment Share on other sites More sharing options...
2jzEd Posted August 23, 2014 Author Share Posted August 23, 2014 (edited) Cam seals were the cause of my oil leak, not the relief valve. Did them while doing a timing belt change. Edited August 24, 2014 by 2jzEd (see edit history) Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 23, 2014 Share Posted August 23, 2014 They took some time to arrive..... Link to comment Share on other sites More sharing options...
2jzEd Posted August 23, 2014 Author Share Posted August 23, 2014 I did them that same year actually. I forgot to follow up for some reason... Link to comment Share on other sites More sharing options...
