Oil/ water lines for HKS Gt2835 setup
stuart hydzik
Hi Guys,
I have fresh HKS gt2835 twin kit.
To complete the instal I would like to use oil and water braided lines with Earls fittings.
Has any one done this before?
Please post here if you got any suggestions regarding hose sizes, thread sizes, line lengths ect.
AN fittings are not cheap so I rather ask you guys to get it right first time:)
Thank you in advance,
Stuart
Did you guys still use banjo bolts on the oil feed side on the turbos or did you replace the with the AN flanges?
Also on the oil return side can I use -AN 10 fittings and lines, I already have -AN 10 flanges welded on to the sump?
I am not sure what is the original size of the oil return. Is it ok to go with -an10.
