Supe died 2 mins after leaving work. Fuel Pump issue? AM2 fuse blown. Please help!
Mike25tt
My Supra started up fine after finishing work and pulled out of the carpark...2nd gear....3rd gear then total loss of power. It just died on me. I tried to start the car afterwards but nothing. I also tried bumping it off and nothing.
I've checked the fuses in the engine bay and the AM2 30amp fuse has blown. I replaced this and tried firing it up and nothing apart from the fuse blowing out again.
The engine is trying to turn over, the battery is fine, ignition fuses are fine. Is this a fuel pump issue? as I can't hear it whirr up. Should it make a noise when the ignition is turned? I fitted a Walbro pump back in 2006 and havn't had any problems before. Is the car flooded?.....I'm sure the red "barbeque" looking light flashed up (next to the battery light) when the supe cut out. What is this light?......or has a connection burned out to the fuel pump or pump ecu?
I'm currently stranded in Wakefield now and staying at a mates house until I can get this sorted. Please help!!!
You could try taking off the fuel feed hose and see if any squirts out (safely if possible) :) I'd pop down and give you a hand but unfortunately I'm away from home until next week. :(
Usually if a fuse is blowing, it means there's a short somewhere. you mighty need to re-check your wiring for the walbro to make sure there's not a +ve shorting against the body or anything like that.
Edited by Iky (see edit history)
You should be able to hear the pump if it's a walbro. I blew that fuse in the past. I forget how now.
It was your VSV connector flapping in the fan blade that had broken up and the spring fingers had welded themselves together.
I've had a little play in the work's car park this morning but couldn't find anything.
I will have a look at the fuel pump after work. Failing that, I've got a mechanic coming round do a diagnostics check.
You can isolate the pump therefore eliminating it from the equation at the pump control ecu tucked away in the boot on the passenger side panel.
I've finally had a chance to look at the electrical stuff, and if AM2 is blowing it won't be your fuel pump, it's not part of that circuit. AM2 goes to the ignition switch and is run off key position 2. The fuel pump won't be spinning up because the ECU isn't seeing an ignition key on event, so it's not activating the pump.
AM2 feeds these things:
7.5amp IGN fuse, which in turn goes to the ECU's IGSW input
The igniter, the six coil packs, and the noise filter
The six injectors (via the resistor pack if you have one) and from there to the ECU.
So, check the 7.5amp IGN fuse first. If that's also blown, your short is between that and the ECU. I imagine it's not though. My money is on the igniter pack as it's high amps and on the suspension turret it could be exposed to moisture or some sort of cable damage. There are several diagnostic steps you can take to try and narrow down the fault location, but have a look at what I've mentioned first and if you can't find anything we can go into more detail :)
Thanks very much for your help Ian. That's brilliant.
I did out of course, check the ignition fuse last night in my work's carpark and that wasn't blown so your on the mark!
The mechanic didn't turn up today as he had contract work on so he's supposed to be calling mid-morning tomorrow to run diagnostic's.
The AM2 fuse blows as soon as I turn the ignition one click I think as I tried it this morning.
There are plugs you can disconnect to isolate parts of this wiring loom, then simply test continuity to earth. Easy :) I'll detail them tomorrow if you like.
Cheers Ian. That would be really helpful as it would save me time and money!
  • 3 years later...
