redsupraman82 Posted March 21, 2012 Share Posted March 21, 2012 ok so starting to lose the love now, its just one thing after another... so i needed to change my rear brake pads, of which i have done before on my old supra. done the offside, no probs took 10 min, then i went to tackle the drivers side and i could not get the piston back in! so i had to remove the top part of the caliper to sort the piston out. finally got it back in, put the brake line back on and then went to tighten up my bleed nipple and SNAP! it broke off! (my own fault i know!) so now i have air in my brake system and the pedal is all soft! how do i get round this...i know im going to have to get hold of another j spec rear caliper as it will be easier than drilling that nipple out and retheading but i take it i will have to bleed the whole system now?? Please advise! [sHOCK][/sHOCK] Link to comment Share on other sites More sharing options...
mellonman Posted March 21, 2012 Share Posted March 21, 2012 give keron a call or pm i expect a jspec calipar is cheap as chips Link to comment Share on other sites More sharing options...
welshbuddy Posted March 21, 2012 Share Posted March 21, 2012 if there is air in the system, dont you have to bleed the whole lot?.... i could be wrong .. Link to comment Share on other sites More sharing options...
mellonman Posted March 21, 2012 Share Posted March 21, 2012 with the damaged bleed nipple there is no piont you will get air back into the system,the nipple needs replacing which you could drill to almost the same size so then you can get whats left of the nipple out or just get another calipar for ease as at a gues the might be cheaper then the effort involved reparing old one Link to comment Share on other sites More sharing options...
redsupraman82 Posted March 21, 2012 Author Share Posted March 21, 2012 thats what i thought, i wouldnt bleed the system with that damaged nipple anyway. so new caliper it is then! poo! Link to comment Share on other sites More sharing options...
Ian C Posted March 22, 2012 Share Posted March 22, 2012 You can clamp the hose (provided it's not braided) with mole grips when you swap the caliper, then you'll only have to rebleed that corner Link to comment Share on other sites More sharing options...
