Shane Posted March 21, 2012 Share Posted March 21, 2012 What size belt are people using other than stock? In fact what is Mr T's OEM size? I have just replaced mine with a Quinton Hazel from a local factor Co. who say it should be a 1932mm, reading through past threads (some dating back to 05) I see some people have different ideas on what should be used ranging from 1932mm up to 1955mm. The QH 1932mm one I have fitted seems way too tight for my liking and I feel is putting strain on the whole belt drive train with the idler tensioner pushed hard over. I am tempted to go for a 1955mm but curious to know what others have found. Camskill do the whole range and charge £17 for any in the whole range. Quote Link to comment Share on other sites More sharing options...
Iky Posted March 22, 2012 Share Posted March 22, 2012 I'm pretty sure the oem size is 1938mm I would just get an oem one, they're not all that much more expensive than others. Unless you're running different pullies/ non a/c. ? Quote Link to comment Share on other sites More sharing options...
Shane Posted March 23, 2012 Author Share Posted March 23, 2012 I'm pretty sure the oem size is 1938mm I would just get an oem one, they're not all that much more expensive than others. Unless you're running different pullies/ non a/c. ? Thanks for that, the only non oem pulley I am running at the moment is the new nylon idler I swapped with DavidP as he needed my steel one for his supercharger project. The old belt was a 1938 and I still feel that was a bit tight too, but will probably go for another. Out of interest, a 6pk1955 is available off the shelves at any GSF car parts outlet, made by either Gates or Dayco for £11, and although I wouldnt want to bet my life on it, I would guess Mr T's are made by either Gates or Dayco. The 6pk1955 is shared with lots of Renaults and also a Escort RS2000. Quote Link to comment Share on other sites More sharing options...
