Aircon Pump mounting bolt size
SamuraiFlash
Hi Guys,
I have previously removed the aircon pump and bits that go with it. I have recently found out via Chris Wilson that the Power steering pump needs the extra support without the aircon pump not being there.
I have with the advice of Hodge stripped the aircon pump and got the bracket off that, to stick back onto the power steering pump and block. The problem is I dont have the original nuts and bolts :(
Does anyone know the thread and length on the bolt's i'll need to fit the aircon pump bracket back on?
:thanks:
hia mate, i have removed my air con pump too,
ive got the old bolts that kept it on (5 in total?)
i only used 2 of them to put my brace back on, so i THINK i have spare left overs up my garage.
i can see if they are there which your welcome to have, if not i can remove my 2 bolts there and measure them up for you. this will be on satuarday when i go up my garage though
