ECU options and info
mellonman
I want to start a thread to help people pick what ecu they go for and what options are out there im still new to all the single turbo stuff and it gets asked so much about ecu but what ones are good and what cost
syvecs 6
stand alone
great ecu, with traction control,knock control,great safeties for the engine
single turbo suited
£1,600
motec 600
stand alone
one of the best,does have lots of features but have to pay for them separatly
single turbo suited
from £2000 - £4,000 inc vat
AEM v1
stand alone
known to fail,need a hks dli (spark amp)
single turbo suited
AEM v2
stand alone
generally okay
single turbo suited
AEM fic
piggy back
has problems with magnetic sensors, which can cause a miss fire if on wrong firmware z107 is the better firmware for the supra,no safety features,just fuel and timing very basic ECU,resolution 21x17,boost control (fic8).
hybrid/parallel suited
£300
HKS fcon
piggy back
HKS Fcon Vpro
stand alone
single turbo suited
APEXI power fc?
knock control,good ecu older and becoming rare
single suited
£800-£1000
APEXI safc
piggy back
most basic control over anything it just adjusts fuel,but has knock monitor
parallel suited
MAP2 ECU?
Emanage Blue
piggy back
Emanage ulitmate
Emerald k6
6xinjector, 6xignition, 4xtraction/abs, 3xmaps, can bus, wide band correction, egt correction,16x32 resilution,boost control
£595 + vat
Megasquirt 3 with MS3X
Switchable fuel maps, launch control, knock control, boost control, safety limiters (oil pressure, oil temp, water temp, fuel pressure), canbus (for racelogic dash), traction control
single suited
£400
link
Well as you can tell i dont know much about ECU's but can people please share there knowledge and experiances on ECU's with features and what you think there problems are and what they are best suited for, add ones that i have not put up
or if you think this is a wasted idea
Edited by mellonman (see edit history)
  • Replies 91
  • 1 month later...
I was searching for some ecu info and found this thread.. Good one Mellonman.. As you know I to have an AEM FIC and is looking at alternatives. My plan was Syvecs but with a baby on the way there is no way I can spend £2k on an ecu.. So what the verdict on alternatives to the Syvecs?
Megasquirt MS3X
I'm running a single and is hoping to upgrade my injectors to 800 or 1000cc. Would the megasquirt handle this? I like to option you get with the Emerald k6
I've got some ID1600's in my V8, it runs that fine. Switchable fuel maps, launch control, knock control, boost control, safety limiters (oil pressure, oil temp, water temp, fuel pressure), canbus (for racelogic dash), traction control etc etc etc. I've yet to find something it can't do, being open source, it's widely supported too with a forum ready to help anyone out.
Find a trusted mapper and go with whatever ecu he advises is my advice, not many people i would trust with my car.
Ryan and a syvecs is my number 1 choice, if he was not about id go Dave rowe and motec, next in line would be Dan turner and an AEM.
