Fast and Furious Replica (Orange Supra) - Take 2
pbryant_knight
Have you got an email address I can send a file to Peter?
I have an outline drawing of the leg but when I try to scan it onto the computer the scanner keeps cropping the image so there is always a little portion missing.
I can scan the actual part itself onto the computer and send you a 1:1 scale image of the support that you can take the necessary measurements from.
It just fits onto an A4 sheet of paper so when you print it off it'll be exactly the same size as the actual part.
Hope that is of some use.
  • Replies 489
Cheers mate.
Just need to get some more accurate wheels. The BK ones were the right look but I thought 17" was a bit too small.
17's will look odd I think, the car looks great as is, I would wait for the right size to come up mate then splash the cash. Looking brilliant though, are you doing the seats too?
  • 3 months later...
Here are some pics with new wheels on.
Bought these Antera 19" wheels from ebay at what i thought was a good price. Noticed that they came with flush fit valves but no adapter. Got the seller to send me an adapter as he didn't have the original and it didn't fit. Ended up having to get the holes drilled out to fit a regular valve as the Flush Fit's were made for the wheels and used a smaller hole.
After that i wen't for some spigots to be told that they were a direct fit and the spigot was there but had slightly rusted and blended to the wheel. Really happy about this, i got home tyo find out that there was 1 spigot ring missing. As i couldn't get just 1 i had to order 4, which was even more money i didn't really want to spend on the wheels.
Anyway, here they are and they look a lot closer to the films wheels than the Veilside Andrews i had on before.
Peter
The gap is gone now mate. I'd just lowered it off the jack and it settled after I took it for a drive. I think I may need to get the rear arches rolled after all as there is only about 10mm clearance at rest between the wheel and arch and I had some rubbing last night on dips and bumps.
Ill get some pics of both cars together today providing it doesn't rain again. :(
The old veilside Andrews are going up for sale when I clean them up.
Peter
