JMB Posted March 17, 2012 Share Posted March 17, 2012 Hi all, I am going to install a FMIC (whifbitz:eyebrows:) but I was wondering if I should not install a new radiator or add a fan between the fmic and the radiator. I read on Internet that the fmic is a "cause" of overheating because of less air flow to the radiator. ThE fact is that my car is an auto, so I am totally afraid of changing the radiator as it cools my transmission too.. Advices are more then welcome Quote Link to comment Share on other sites More sharing options...
Guest hockysa Posted March 17, 2012 Share Posted March 17, 2012 are you doing track work? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 17, 2012 Share Posted March 17, 2012 No you dont need a new rad, or to add a fan, the car will not overheat by just adding an inter cooler, unless you have an underlying problem, like a weak viscous fan or something. Quote Link to comment Share on other sites More sharing options...
JMB Posted March 17, 2012 Author Share Posted March 17, 2012 Thanks guys, I am essentially doing drag racing... Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 17, 2012 Share Posted March 17, 2012 Lots of drag racing? Quote Link to comment Share on other sites More sharing options...
Nic Posted March 17, 2012 Share Posted March 17, 2012 You don't need to fit a new radiator when you fit a FMIC, however if your current radiator is in poor condition then the reduction in air flow could cause overheating issues. Quote Link to comment Share on other sites More sharing options...
JMB Posted March 17, 2012 Author Share Posted March 17, 2012 Yes lots of drag racing... This is the purpose of the car Ok, I ll first fit the FMIC and I'll check the temp gauge, by the way can I trust the OEM gauges ? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 17, 2012 Share Posted March 17, 2012 If you're doing lots of drag racing I assume you would already have an updated radiator, you will certainly need a great big auto box fluid cooler. Quote Link to comment Share on other sites More sharing options...
JMB Posted March 17, 2012 Author Share Posted March 17, 2012 If you're doing lots of drag racing I assume you would already have an updated radiator, you will certainly need a great big auto box fluid cooler. I should have one but I am afraid of doing this mod because of the auto box cooler... Where to put it ? How do I install it ? Which cooler ? Etc... Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 17, 2012 Share Posted March 17, 2012 The cooler is just another radiator, depending on your bumper you could put it between the inter cooler and the rad, or in front of one of the front wheels. Traders here like Lee at SRD or Paul at Whifbitz sell hih quality oil cooler kits with instructions Quote Link to comment Share on other sites More sharing options...
JMB Posted March 18, 2012 Author Share Posted March 18, 2012 Thanks, Do you know if there is a good DIY, so that I ll be able to do it myself ? I am not a specialist but I take... Quote Link to comment Share on other sites More sharing options...
GTR Fever Posted March 18, 2012 Share Posted March 18, 2012 don't know if this would help but i changed my rad to a Mishimoto 3-core and at the same time installed the Mishimoto transmission cooler. Before i changed the rad my car's temp gauge would go up to 3/4 (the daily temp. here is 34 degrees celcius though) cools perfectly fine now, both engine and transmission Quote Link to comment Share on other sites More sharing options...
