Supra N_A Posted March 16, 2012 Share Posted March 16, 2012 will be seeing more mpg for sure looks identical to the toyota lambda sensor! half the price! will report back on this to see how it is going ! a good few people have noticed huge difference in fuel both together toyota sensor also buffed my headlights and got this result like new alot of muck came of these so it is worth wile doing so... Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted March 16, 2012 Share Posted March 16, 2012 Damn, that was quick... Good luck.. Quote Link to comment Share on other sites More sharing options...
Josh Posted March 16, 2012 Share Posted March 16, 2012 Nice work Quote Link to comment Share on other sites More sharing options...
Ross C Posted March 16, 2012 Share Posted March 16, 2012 god i really need to do my headlights after seeing these. nice work make, keep it up Quote Link to comment Share on other sites More sharing options...
Westy Posted March 16, 2012 Share Posted March 16, 2012 Link to where you got it with part number please!? Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted March 16, 2012 Author Share Posted March 16, 2012 right you kno on the boost gauge where it has -0.1 for example when aye start the car at idle reads like it used to -0.7 to -0.6 but now it goes to -0.9 when driving and backing of the boost.. what is that reading as thought it was just boost only ?? Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted March 16, 2012 Author Share Posted March 16, 2012 Link to where you got it with part number please!? here you go mate what you want DOX-0228 from here http://www.sparkplugs.co.uk/ also you want the "front" sensor Quote Link to comment Share on other sites More sharing options...
Colin-mkiv Posted March 31, 2012 Share Posted March 31, 2012 The lambda after the 1st cat in an NA, is that a different type of sensor to the one above?....the reason that I ask is, I replaced the gasket between my 1st cat and the centrepipe and the sensor I saw was a longer, thinner one, almost like ceramic if that makes any sense? It has the same flange fitting as the one above, but the actual sensor is leaking and the bolt heads are so rusted that they are barely recogniseable! I dont want to swap it only to find I have the wrong replacement one. Quote Link to comment Share on other sites More sharing options...
Nic Posted March 31, 2012 Share Posted March 31, 2012 The lambda after the 1st cat in an NA, is that a different type of sensor to the one above?....the reason that I ask is, I replaced the gasket between my 1st cat and the centrepipe and the sensor I saw was a longer, thinner one, almost like ceramic if that makes any sense? It has the same flange fitting as the one above, but the actual sensor is leaking and the bolt heads are so rusted that they are barely recogniseable! I dont want to swap it only to find I have the wrong replacement one. There are 2 oxygen sensors on the NA one in each of the 2 cast exhaust manifolds. The one in the cat is a temperature sensor, it illuminates the cat overheating warning light on the dash, it has no effect on performance and can be removed if need be. Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted April 23, 2012 Share Posted April 23, 2012 Would this sensor be suitable for a 94 TT is that a different part no? Quote Link to comment Share on other sites More sharing options...
Colin-mkiv Posted April 23, 2012 Share Posted April 23, 2012 Cheers Nic There are 2 oxygen sensors on the NA one in each of the 2 cast exhaust manifolds. The one in the cat is a temperature sensor, it illuminates the cat overheating warning light on the dash, it has no effect on performance and can be removed if need be. Quote Link to comment Share on other sites More sharing options...
Robzki Posted April 23, 2012 Share Posted April 23, 2012 Would this sensor be suitable for a 94 TT is that a different part no? I've just fitted an dox-0228 in my 95 TT so should be good. Quote Link to comment Share on other sites More sharing options...
Lude Posted April 23, 2012 Share Posted April 23, 2012 can the op advise if noticible difference in fuel? Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted April 23, 2012 Share Posted April 23, 2012 I've just fitted an dox-0228 in my 95 TT so should be good. cheers Rob Quote Link to comment Share on other sites More sharing options...
supra steveo Posted April 23, 2012 Share Posted April 23, 2012 can the op advise if noticible difference in fuel? Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted April 23, 2012 Share Posted April 23, 2012 I changed for the same one on my TT and it made very little difference. But I do think that I had other issues. Have just changed the ECU temp sensor and all of the vacuum hoses so will take her for a run to see as soon as I get the time to actually drive her... Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted May 19, 2012 Share Posted May 19, 2012 Has the OP had any better MPG since he swapped the O2 sensors over? Quote Link to comment Share on other sites More sharing options...
SupraJames Posted May 19, 2012 Share Posted May 19, 2012 Any ideas which ones would fit a UK spec, as believe the UK has 2 sensors ? Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted May 20, 2012 Share Posted May 20, 2012 any update on this?? Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted July 17, 2012 Share Posted July 17, 2012 Just changed mine for a new one: all done in 20 mins, downside is despite soaking the bolts/nuts in plusgas for the past 2 days one of the studs snapped off half way up..... so this will have to wait until the weekend until I can drill it out and fit another. Hopefully its ok to drive until then. ffs. Bugger. Quote Link to comment Share on other sites More sharing options...
Pulley Posted July 17, 2012 Share Posted July 17, 2012 (edited) I'm confused, in one thread about cleaning na O2 sensors I've seen and read that they are both the same, I look at mine and I have one (nearest the front of the engine) with a single wire, and the rear sensor with 4 wires (which I assumed was because my greddy afr gauge shares this with the ecu do it's different from standard?) But the pic shown here shows a multiple wire sensor ? Just realised I was assuming the op had an na because of name Edited July 17, 2012 by Pulley (see edit history) Quote Link to comment Share on other sites More sharing options...
Geo Posted July 17, 2012 Share Posted July 17, 2012 NA has 1 wire leading to plug, the TT has 4 wires i believe? 89465-19635 Oxygen Sensor - J-spec TT 89465-19725 Oxygen Sensor - J-spec TT VVTi 89465-19605 Oxygen Sensor - Front - UK Spec 89465-19595 Oxygen Sensor - Rear - UK Spec 89465-19615 Oxygen Sensor - NA x 2 Quote Link to comment Share on other sites More sharing options...
Pulley Posted July 17, 2012 Share Posted July 17, 2012 Cheers for that helpful bit of info geo, my rearmost sensor must be a greddy one as it has 4 wires and one wire is passed back from the afr module to the stock o2 socket Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted July 23, 2012 Share Posted July 23, 2012 I have noticed a massive difference in comsumption with the new sensor, didnt realise just how goosed my old one was! Quote Link to comment Share on other sites More sharing options...
tony tt Posted July 23, 2012 Share Posted July 23, 2012 I have noticed a massive difference in comsumption with the new sensor, didnt realise just how goosed my old one was! A job worth doing then? Quote Link to comment Share on other sites More sharing options...
