SRD Built Engines
Lee P
We are now offering built engines as seen in Jamiep's black beast, these will be made to order but will be keeping one in stock at a time.
These will require an exchange unit, a surcharge will be applied if its not available at the time of purchase. *
Stage 1 £4400
Mahle 86.5mm or Manley 87mm Pistons
Manley or BC Pro Series Rods (Add Carrillo HD Rods for £680)
Clevite Bearings
ARP Main Studs
New Oil Squirters
New Core Plugs
Polished Crankshaft
All fully balanced, machined and assembled
Stage 2 £5200
Clevite Bearings
SRD Brace Kit
New Oil Squirters
New Core Plugs
Polished Crankshaft
All Fully balanced, machined and assembled
Stage 3 £8200 **
Mahle 3.4L Pistons
Manley or BC Pro Series Rods (Add carrillo HD Rods for £680)
Titan Stroker Crank
SRD Brace Kit with ARP studs
Clevite Bearings
New Core Plugs
All Fully balanced Machined and assembled
Optional and extra parts Parts
New Toyota oil pump £233
New toyota water pump £220
Full engine gasket set £385
Timing Belt £37
Kevlar Timing belt £88
Billet Tensioner bracket £180
Toyota idler Wheel £66
Toyota Tensioner. £70
Fluidampr £396
SRD Heads, these will be built from your original units or on an exchange basis. We can also built with brand new heads for an additional charge (TBC)
Stage 1 Head £800
Full refresh using stock components
Reshim and Skim
Valve and Seat Machine Work
New Stem Seals
New Cam seals
Add SRD Stage 1 Cams for £570
Stage 2 Head £1200
Full Refresh using stock components
Reshim and Skim
New Stem Seals
New Cam Seals
Port work
Add SRD stage 1 cams for £570
Add HKS VVTI 264 Cams for £972
Stage 3 Head £1600
Full Head Refresh using stock components
BC Uprated Springs with Titanium Retainers
Reshim and Skim
New Stem Seals
New Cam Seals
Port work
Add SRD Stage 2 Cams for £570
Stage 4 Head £2500
BC Stock Size Stainless Steel Valve set
BC Billet Valve Locks
BC Springs and Titanium Retainers ( Dual springs needed for Stage 3 cams, add £250)
Port work
All Machine Work
New Cam Seals
New Stem Seals
Reshim and Skim
Add SRD Stage 2 cams for £570
Add SRD Stage 3 cams for £570
Add Bronze Valve Guides for £280
Add 1mm Over Sized Valves for £280
Stage 5 Race Head £3500
Ferrea Valve Train Set Including 1mm OS Valves
Ferrea Dual valve Springs
Ferrea Valve Locks,
Ferrea Titanium Retailners
Ferrea Spring seat locators
Ferrea Bronze Valve Guides
Race Port or Street Race dpending on application
New Cam Seals
New Stem Seal
All Machine Work
Add GSC VVTI Cams for £1180
Add Kelford VVTI Cams for £1050
Add Shimless Buckets for £490
ARP Head Stud Kit £179
ARP L19 Stud Kit £360
HKS Cam Pulleys £275
HKS Head Gaskets from £270
* Exchange unit will need to be in reusable condition and complete with crankshaft to return surcharge.
** Stroker engines will be made to order, 12 weeks estimated
Edited by Lee P (see edit history)
Hi Lee, do you/can you get the heads flow tested and optimised?
Yes Steve this can be done, tbh we have the port and polishing down to a fine art now but can customise it to any setup.
We can supply flow test figures if required but obviously as extra cost.
Yes Steve this can be done, tbh we have the port and polishing down to a fine art now but can customise it to any setup or manifolds.
Excellent Lee - I will be after some of your skills later in the year, just got to work out what order of attack makes sense for all the jobs I want to get done. :)
So far I have - bushes first, respray last, everything else in between!
  • 4 months later...
Are there any real gains for port and polish (stage 2 head) on a small single? Aiming for just 600-700 hp, wide powerband not just top end power.
There are always benifits but it's about matching the head to the turbo being used and making the most of the cams. Larger turbos and cams will increase air flow but other things need to be done to match this including head work.
These things will increase mid range torque as well as top end power
