Lee P Posted March 14, 2012 Share Posted March 14, 2012 (edited) We are now offering built engines as seen in Jamiep's black beast, these will be made to order but will be keeping one in stock at a time. These will require an exchange unit, a surcharge will be applied if its not available at the time of purchase. * Stage 1 £4400 Mahle 86.5mm or Manley 87mm Pistons Manley or BC Pro Series Rods (Add Carrillo HD Rods for £680) Clevite Bearings ARP Main Studs New Oil Squirters New Core Plugs Polished Crankshaft All fully balanced, machined and assembled Stage 2 £5200 Mahle 86.5mm or Manley 87mm Pistons Manley or BC Pro Series Rods (Add Carrillo HD Rods for £680) Clevite Bearings SRD Brace Kit New Oil Squirters New Core Plugs Polished Crankshaft All Fully balanced, machined and assembled Stage 3 £8200 ** Mahle 3.4L Pistons Manley or BC Pro Series Rods (Add carrillo HD Rods for £680) Titan Stroker Crank SRD Brace Kit with ARP studs Clevite Bearings New Core Plugs All Fully balanced Machined and assembled Optional and extra parts Parts New Toyota oil pump £233 New toyota water pump £220 Full engine gasket set £385 Timing Belt £37 Kevlar Timing belt £88 Billet Tensioner bracket £180 Toyota idler Wheel £66 Toyota Tensioner. £70 Fluidampr £396 SRD Heads, these will be built from your original units or on an exchange basis. We can also built with brand new heads for an additional charge (TBC) Stage 1 Head £800 Full refresh using stock components Reshim and Skim Valve and Seat Machine Work New Stem Seals New Cam seals Add SRD Stage 1 Cams for £570 Stage 2 Head £1200 Full Refresh using stock components Reshim and Skim Valve and Seat Machine Work New Stem Seals New Cam Seals Port work Add SRD stage 1 cams for £570 Add HKS VVTI 264 Cams for £972 Stage 3 Head £1600 Full Head Refresh using stock components BC Uprated Springs with Titanium Retainers Reshim and Skim Valve and Seat Machine Work New Stem Seals New Cam Seals Port work Add SRD Stage 2 Cams for £570 Add HKS VVTI 264 Cams for £972 Stage 4 Head £2500 BC Stock Size Stainless Steel Valve set BC Billet Valve Locks BC Springs and Titanium Retainers ( Dual springs needed for Stage 3 cams, add £250) Port work All Machine Work New Cam Seals New Stem Seals Reshim and Skim Add SRD Stage 2 cams for £570 Add SRD Stage 3 cams for £570 Add HKS VVTI 264 Cams for £972 Add Bronze Valve Guides for £280 Add 1mm Over Sized Valves for £280 Stage 5 Race Head £3500 Ferrea Valve Train Set Including 1mm OS Valves Ferrea Dual valve Springs Ferrea Valve Locks, Ferrea Titanium Retailners Ferrea Spring seat locators Ferrea Bronze Valve Guides Race Port or Street Race dpending on application New Cam Seals New Stem Seal All Machine Work Add SRD Stage 3 cams for £570 Add HKS VVTI 264 Cams for £972 Add GSC VVTI Cams for £1180 Add Kelford VVTI Cams for £1050 Add Shimless Buckets for £490 Optional and extra parts ARP Head Stud Kit £179 ARP L19 Stud Kit £360 HKS Cam Pulleys £275 HKS Head Gaskets from £270 * Exchange unit will need to be in reusable condition and complete with crankshaft to return surcharge. ** Stroker engines will be made to order, 12 weeks estimated Edited May 1, 2020 by Lee P (see edit history) Link to comment Share on other sites More sharing options...
Ricky49 Posted March 14, 2012 Share Posted March 14, 2012 (edited) Oooooo you are a tease Mr P Nice addition mate after we move I want one of these. Edited March 14, 2012 by Ricky49 (see edit history) Link to comment Share on other sites More sharing options...
pezzler Posted March 14, 2012 Share Posted March 14, 2012 Fantastic (I never say fantastic) price for the stroker Thought a built motor would be pricier, I can afford one after all Link to comment Share on other sites More sharing options...
bradleyh_15 Posted March 14, 2012 Share Posted March 14, 2012 Fantastic (I never say fantastic) price for the stroker Thought a built motor would be pricier, I can afford one after all Get buying one then Link to comment Share on other sites More sharing options...
Lee P Posted March 14, 2012 Author Share Posted March 14, 2012 Updated with head info Link to comment Share on other sites More sharing options...
James Posted March 14, 2012 Share Posted March 14, 2012 Some day! Link to comment Share on other sites More sharing options...
Westy Posted March 14, 2012 Share Posted March 14, 2012 Nice Lee! Could spend a fortune looking at the lists! Link to comment Share on other sites More sharing options...
tkddav3 Posted March 14, 2012 Share Posted March 14, 2012 if only i had more money. cracking prices though! Link to comment Share on other sites More sharing options...
hodge Posted March 15, 2012 Share Posted March 15, 2012 Those are great prices for built engines. Link to comment Share on other sites More sharing options...
JamieP Posted March 15, 2012 Share Posted March 15, 2012 Great prices, that 3.4L would be nice to have. Link to comment Share on other sites More sharing options...
mellonman Posted March 15, 2012 Share Posted March 15, 2012 great stuff lee just what i was after thanks for the help Link to comment Share on other sites More sharing options...
Geo Posted March 15, 2012 Share Posted March 15, 2012 With each stage Lee, what roughly would be the safe BHP limits? The Stage 1 is taking my fancy, And what would fitting cost roughly? Link to comment Share on other sites More sharing options...
SteveR Posted March 15, 2012 Share Posted March 15, 2012 Hi Lee, do you/can you get the heads flow tested and optimised? Link to comment Share on other sites More sharing options...
Lee P Posted March 15, 2012 Author Share Posted March 15, 2012 (edited) Hi Lee, do you/can you get the heads flow tested and optimised? Yes Steve this can be done, tbh we have the port and polishing down to a fine art now but can customise it to any setup. We can supply flow test figures if required but obviously as extra cost. Edited March 15, 2012 by Lee P (see edit history) Link to comment Share on other sites More sharing options...
Jamesy Posted March 15, 2012 Share Posted March 15, 2012 Having the SRD built head in my car made the world of difference - serious bit of kit this is Link to comment Share on other sites More sharing options...
SteveR Posted March 15, 2012 Share Posted March 15, 2012 Yes Steve this can be done, tbh we have the port and polishing down to a fine art now but can customise it to any setup or manifolds. Excellent Lee - I will be after some of your skills later in the year, just got to work out what order of attack makes sense for all the jobs I want to get done. So far I have - bushes first, respray last, everything else in between! Link to comment Share on other sites More sharing options...
Wez Posted March 15, 2012 Share Posted March 15, 2012 Very nice Link to comment Share on other sites More sharing options...
Littler Posted March 15, 2012 Share Posted March 15, 2012 Some great options Lee! Link to comment Share on other sites More sharing options...
ADZsupra Posted March 15, 2012 Share Posted March 15, 2012 I 2nd that Jamesy! Link to comment Share on other sites More sharing options...
Ricky49 Posted March 19, 2012 Share Posted March 19, 2012 (edited) Lee can you get me a price on a brand new stock head please boss, looking at possible a stage 2 head so just a port and polish required, but i want to keep my head as a spare. You could may be squeeze me for a stage 3. Chat tomorrow Edited March 19, 2012 by Ricky49 (see edit history) Link to comment Share on other sites More sharing options...
rsme Posted August 13, 2012 Share Posted August 13, 2012 Are there any real gains for port and polish (stage 2 head) on a small single? Aiming for just 600-700 hp, wide powerband not just top end power. Link to comment Share on other sites More sharing options...
Lee P Posted August 15, 2012 Author Share Posted August 15, 2012 Are there any real gains for port and polish (stage 2 head) on a small single? Aiming for just 600-700 hp, wide powerband not just top end power. There are always benifits but it's about matching the head to the turbo being used and making the most of the cams. Larger turbos and cams will increase air flow but other things need to be done to match this including head work. These things will increase mid range torque as well as top end power Link to comment Share on other sites More sharing options...
