Mike B Posted March 14, 2012 Share Posted March 14, 2012 Hi All, My car has a (now leaking) aftermarket oil cooler for the PAS system. It's a louvred system - 30x30cm and it has breached.. Would I be correct in thinking that it has breached because the PAS system uses a lot more pressure than a standard oil cooler? (which I think this is) Do you have any recommendations as to a a cooler that would do the job, any that you have used so far? or will a standard oils cooler do the job? :-) Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 14, 2012 Share Posted March 14, 2012 Do you do a lot of track time? If not, the stock one should do fine, which consists of a bent section of metal pipe lol. Coolers leak for many reasons, corrosion, manufacturing flaws etc. there's really a lot of pressure in the system. Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted March 15, 2012 Share Posted March 15, 2012 i thought the pas system (the lp side) had very little pressure in it? I have mine on with barbed fittings and jubilee clips. If yours is leaking its probably taken a knock or the lines going to it are putting stress on the brazed ends or something. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 15, 2012 Share Posted March 15, 2012 i thought the pas system (the lp side) had very little pressure in it?. I appear to have missed a 'not' out of that post lol Quote Link to comment Share on other sites More sharing options...
hodge Posted March 15, 2012 Share Posted March 15, 2012 They are under very little pressure and to be honest, if your car is not getting put on a track regularly just take it out and put it in the bin. I'm currently running a 10 row cooler but it's just turned out to be just clutter to me stopping air going to the rad as far as I'm concerned. I'm removing it in a week or do and won't be running one at all. Quote Link to comment Share on other sites More sharing options...
Mike B Posted March 15, 2012 Author Share Posted March 15, 2012 It gets tracked very rarely, if ever these days, and the pas cooler sat right in front of the mocal oil cooler, so I may try and find a workaround as suggested.. The existing unit is leaking somewhere inside the cooler, hard to see where from.. Thanks for you input as always.. Quote Link to comment Share on other sites More sharing options...
sideexitsupra Posted March 15, 2012 Share Posted March 15, 2012 Paul Whiffin does a relocation bent pipe for this. I have one sat behind my oil cooler and not had any issues with it. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 15, 2012 Share Posted March 15, 2012 The cooler *SHOULD* be in the return line, and I am sure it is as near 1000PSI would have totalled it straight away, otherwise. Usually two reasons for cooler failure. Junk cooler, or rigidly mounted and hoses or vibration stressing the unit. By *FAR* the beat way on a manual is buy an auto rad and use the cooler integrated into the bottom tank of the rad for the PAS. Track days on tight tracks like that little place in south Wales NEED a PAS cooler as the constant wheel twirling at slow speeds imparts a lot of load on the system and the fluid can boil or the seals in the pump or rack can be made to go hard and fail. Quote Link to comment Share on other sites More sharing options...
Mike B Posted March 15, 2012 Author Share Posted March 15, 2012 Thanks Chris.. I did not know that auto rads had an inbuilt cooler.. :-O I have an aftermarket fluidine radiator in her at the mo - so keen to keep it. Sounds like I should get another small cooler to save me replacing the rack further down the line.. I will mount it away from potential stress.. good point. and I'll check to make sure it is in the return line (pretty sure it is) M Quote Link to comment Share on other sites More sharing options...
Wez Posted March 15, 2012 Share Posted March 15, 2012 Plenty on here http://www.summitracing.com/search/?keyword=power%20steering%20cooler&dds=1 Quote Link to comment Share on other sites More sharing options...
Mike B Posted March 15, 2012 Author Share Posted March 15, 2012 Thanx Wez, something small and neat should do the job! Quote Link to comment Share on other sites More sharing options...
