Chris Wilson Posted March 14, 2012 Share Posted March 14, 2012 My high tension oil pump seals, special seal with added lip tension, a good bet for fixing the dreaded front seal leak where the crank has a wear groove worn by the old seal. £28 plus VAT each Rear main bearing seals, 1/3 rd Toyota price, a small job lot, will soon go. My price £16.98 plus VAT. Gear shaft selector seals for six speed manuals, a special seal that doesn't entail you performing the almost impossible task of getting the old seal out without scoring or scratching the selector shaft itself and making things 100 times worse. Just thoroughly clean with brake cleaner, tap the old seal in further, and put the new on in in front of it. A trick used on old BL cars with similar selector shaft issues. These special seals are £4.80 plus VAT each, I have but 6 of them. Cam shaft seals, 1/2 list price. My price £4.60 each. Back in stock!!! Gearbox rear seals, manual 6 speed only, 1/2 Toyota price, very few left. My price £18.82 plus VAT. Postage can be by insured next day courier at £5.80 plus VAT, or a your risk £2.50 plus VAT by normal mail. I pair N/A genuine Toyota multi shim exhaust manifold gaskets, been on an engine that someone brought to me to fit, started it, ran it for 10 minutes, found it a scrapper and he bought a TT conversion. £14 pair. Mint, still retaining embossing, so will definitely seal as new. These are DEAR from Mr T. I set valve stem seals, inlet and exhaust, offers. New of course. One only TT head gasket. 1 set valve stem oil seals 1/2 Toyota price, big saving, these are VERY expensive. Fit none genuine at your peril. Been there.... E-MAIL responses please, not PM's, see sig. Thanks. Link to comment Share on other sites More sharing options...
johnny g Posted March 14, 2012 Share Posted March 14, 2012 Hi Chris - let me have a chat with Lee about whether I'll need a gearbox seal - and get back to you Link to comment Share on other sites More sharing options...
krisso_pl Posted March 15, 2012 Share Posted March 15, 2012 Chris, im desperate! looking for rear crank shaft seal - maybe you have one? OEM is very pricey... Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 15, 2012 Author Share Posted March 15, 2012 Yes, I have a few left, and they are OEM. One THIRD retail plus P&P. Price is in ad. £16.98, plus VAT Would need to get price on P&P if it's to go outside of the UK. E-mail me if you want one please. Link to comment Share on other sites More sharing options...
tkddav3 Posted March 15, 2012 Share Posted March 15, 2012 how much for a gasket kit for the cam covers mate? as fitting new ones and would rather be safe than sorry! cheers Link to comment Share on other sites More sharing options...
jonc Posted March 15, 2012 Share Posted March 15, 2012 Chris, how good are these high tension oil pump seals. I was about to buy a new oil pump and do my engine mounts at the same time. Cheers Jon Link to comment Share on other sites More sharing options...
p3te Posted March 15, 2012 Share Posted March 15, 2012 how much for a gasket kit for the cam covers mate? as fitting new ones and would rather be safe than sorry! cheers Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 15, 2012 Author Share Posted March 15, 2012 how much for a gasket kit for the cam covers mate? as fitting new ones and would rather be safe than sorry! cheers I think they are all gone, if I find any more will post here. Thanks. Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 15, 2012 Author Share Posted March 15, 2012 Chris, how good are these high tension oil pump seals. I was about to buy a new oil pump and do my engine mounts at the same time. Cheers Jon They are a crutch for engines that need a new crankshaft really. If you do not have a wear groove use a stock OE seal, which I should be getting in stock very soon, again at a very good price. Link to comment Share on other sites More sharing options...
Hellstrom Posted March 16, 2012 Share Posted March 16, 2012 Chris ive mailed you about valve steam seals please reply Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 16, 2012 Author Share Posted March 16, 2012 Stem seals retail at £5.67 each plus VAT, so I can do them at £2.84 each plus VAT, that's £2.84 x 24 = £81.80 inc VAT for the seals. I believe I have only the one set. Link to comment Share on other sites More sharing options...
Hellstrom Posted March 16, 2012 Share Posted March 16, 2012 They are 72£ from whiffin Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 16, 2012 Author Share Posted March 16, 2012 For OE Toyota ones? If so, that's the place to get them then Link to comment Share on other sites More sharing options...
Hellstrom Posted March 16, 2012 Share Posted March 16, 2012 Yeah should be oem ones goes under Toyota parts. Okay ill get em off whiffin then Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 16, 2012 Author Share Posted March 16, 2012 Best I can do is match his price with £8.00 P&P. Which is good considering where you are.Just let me be 100% sure there's a full set left, I am 99% on this. Link to comment Share on other sites More sharing options...
Hellstrom Posted March 16, 2012 Share Posted March 16, 2012 Check what you got and send me a mail Chris. Ill take em aslong as its a full set Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 16, 2012 Author Share Posted March 16, 2012 Checked, it is a full set, no worries. Link to comment Share on other sites More sharing options...
SteveC Posted March 20, 2012 Share Posted March 20, 2012 Seals received, thanks Chris. Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 20, 2012 Author Share Posted March 20, 2012 No worries, thanks for the order Steve! Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 20, 2012 Author Share Posted March 20, 2012 Hellstrom, your seals went out yesterday. Link to comment Share on other sites More sharing options...
Hellstrom Posted March 20, 2012 Share Posted March 20, 2012 Cheers mate Will keep an eye out in the mail Link to comment Share on other sites More sharing options...
Hellstrom Posted March 21, 2012 Share Posted March 21, 2012 Arrived today Chris.. seems all good. thanks for the top service and fast delivery! iam off to finally get the freaking cylinder head on now Link to comment Share on other sites More sharing options...
ray007 Posted April 19, 2012 Share Posted April 19, 2012 hi Chris do you have the rear main engine seals? not sure if thats the correct name for it, for a japspec tt please Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 20, 2012 Author Share Posted April 20, 2012 3 left, using one today on a customer's car. £16.98 lus VAT (£20.38) plus £2.50 P&P That's one third price, so a bargain. E-mail me if you want one please [email protected] Link to comment Share on other sites More sharing options...
