scott23 Posted March 14, 2012 Share Posted March 14, 2012 just like to take the time to add some pictures of my slow supra build, hope you like the pictures parts list for the car fitted. body kit as known as a gt300 top secret kit this is the cheap version as i dont have a endless money pit, it arrived to the body shop and think carboard would have been stronger. as you can see from the picture none of it aligned up but thanks to the time spent mere 50/60 hrs it was on but look like it had a bad case of cellulite. 100 hrs went into smoothing and strenghtening the kit before respray. thought id be different so searched every where for a carbon aero roof ( make it easy to carry as i struggle being in wheelchair) found a place that ended up being local, made the moulds then out come was perfection.but sadly didnt fit the roof for 3 months and the carbon had decided to become out of shape so had to make another seibon carbon rear hatch with whifbitz rear plastic seibon carbon bonnet wheels ssr rims provided by whifbitz look great running 265/35/19 bridgestone front and 345/35/19 bridgestone rear brakes : ap 6 pot 356mm front rotora 356mm rear superstreet coilovers with the electronic damper motors (handy for me) gear box: standard a340e broke so decided to fit a 700 r4 think is the 4l60 gm box with manual shifter lovely box uptil 650hp and broke on rollers 3rd gear had let go. so i spoke to paul from whifbits where the car is at this moment of time. decided to go back to a340e from titan performance which say can handle 800 at the wheels so i shall see how this holds up on the 27th march with ryan at 2bartuning maps car engine: well at he time almost 5 years ago i decided to get hks t51 dbb and manifold 272 cams hks pulley wheels and cam belt titan stage 4 head and head internals crank has been polished aftermarket rods and pistons from hks with billet main caps and arp bolts hks crank pulley greedy inlet q45 throttle body hks fuel rail and injectors 1000cc 3 fuel pumps and hardware larger breather hoses and tank racing alu radiator greedy large intercooler electronics hks fcon gold ecu with race logic traction control unit(be for sell shortly) gone over to the syvec ecu greedy boost contoler seats cobra misano seats well small description of the bits fitted hoping to update new pictures when its home but for now heres the build up pictures thanks for reading Quote Link to comment Share on other sites More sharing options...
Jamesy Posted March 14, 2012 Share Posted March 14, 2012 That sounds like a LOT of work on the kit mate!!!!!!!! Quote Link to comment Share on other sites More sharing options...
scott23 Posted March 14, 2012 Author Share Posted March 14, 2012 (edited) Edited March 14, 2012 by scott23 add more pictures (see edit history) Quote Link to comment Share on other sites More sharing options...
scott23 Posted March 14, 2012 Author Share Posted March 14, 2012 i shall add some more pictures when i get home Quote Link to comment Share on other sites More sharing options...
Brazil Posted March 14, 2012 Share Posted March 14, 2012 Wow that budy kit does look really thin...! Nice spec though, look forwards to seeing more photos..! Ps. Does your cobra misano seats rub against the door card? I've recently fitted some but mine slightly rub on the door card..! Maybe I need to try different seat rails? Quote Link to comment Share on other sites More sharing options...
scott23 Posted March 14, 2012 Author Share Posted March 14, 2012 mine did as well what i did was put 2mm spacer washer on right side runners and it clears door card , do you fine your runners stiff mine are well stiff to move Quote Link to comment Share on other sites More sharing options...
scott23 Posted March 14, 2012 Author Share Posted March 14, 2012 Quote Link to comment Share on other sites More sharing options...
Brazil Posted March 14, 2012 Share Posted March 14, 2012 mine did as well what i did was put 2mm spacer washer on right side runners and it clears door card , do you fine your runners stiff mine are well stiff to move Yes they are very stiff and most of the time they can only be adjusted once I am sit on them...! Its also a shame that they don't have the automatic reclining to make it easier to get to the back seats like the OEM ones..! Quote Link to comment Share on other sites More sharing options...
scott23 Posted March 14, 2012 Author Share Posted March 14, 2012 has yours not got the recline bar under the seat at the back or you mean it doesnt recline and move forwards at same time Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted March 14, 2012 Share Posted March 14, 2012 That kit is shocking in the fitment departments. Good luck on the build Quote Link to comment Share on other sites More sharing options...
scott23 Posted March 14, 2012 Author Share Posted March 14, 2012 That kit is shocking in the fitment departments. Good luck on the build it was but the finish is really well done been on car for bout 2.5 yrs now but anyone buying a cheap kit be prepared to spend at least 100hrs + Quote Link to comment Share on other sites More sharing options...
tkddav3 Posted March 14, 2012 Share Posted March 14, 2012 wasnt this the one at last years ace cafe meet.. looked nice in the flesh Quote Link to comment Share on other sites More sharing options...
scott23 Posted March 14, 2012 Author Share Posted March 14, 2012 wasnt this the one at last years ace cafe meet.. looked nice in the flesh ya it was. since then ive blown gear box 3rd gear so not been on road really seen since ace cafe Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted March 14, 2012 Share Posted March 14, 2012 it was but the finish is really well done been on car for bout 2.5 yrs now but anyone buying a cheap kit be prepared to spend at least 100hrs + Yeah i know exactly what you mean Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted March 14, 2012 Share Posted March 14, 2012 AH so you are one here, Im a member on evo cars forum, and a bloke I spoke to when I signed up, said you had a wide body supra and posted some pics, which look alot like yours. Quote Link to comment Share on other sites More sharing options...
Brazil Posted March 14, 2012 Share Posted March 14, 2012 has yours not got the recline bar under the seat at the back or you mean it doesnt recline and move forwards at same time Yes I meant Recline and move forwards at the same time..! Quote Link to comment Share on other sites More sharing options...
