andz222 Posted March 13, 2012 Share Posted March 13, 2012 (edited) this happens only sometimes i lose accelaration and the rev counter moves but the car dont seem to move any faster Edited March 13, 2012 by andz222 (see edit history) Quote Link to comment Share on other sites More sharing options...
ADD Posted March 13, 2012 Share Posted March 13, 2012 release the handbrake then Quote Link to comment Share on other sites More sharing options...
SupraShaun Posted March 13, 2012 Share Posted March 13, 2012 Clutch slipping? Quote Link to comment Share on other sites More sharing options...
andz222 Posted March 13, 2012 Author Share Posted March 13, 2012 yes i think so its slipping in D mode only sometimes Quote Link to comment Share on other sites More sharing options...
ADD Posted March 13, 2012 Share Posted March 13, 2012 manual or auto? Quote Link to comment Share on other sites More sharing options...
andz222 Posted March 13, 2012 Author Share Posted March 13, 2012 auto but the tiptronic function is ok Quote Link to comment Share on other sites More sharing options...
ADD Posted March 13, 2012 Share Posted March 13, 2012 Possible Torque converter problems? are the gear shifts quit slow when moving? Quote Link to comment Share on other sites More sharing options...
andz222 Posted March 13, 2012 Author Share Posted March 13, 2012 gearshifts are spot on when changing gears from buttons on steering wheel but when left in d and i kickdown the car seems to rev say up to 6000 rpm but dont push off Quote Link to comment Share on other sites More sharing options...
Robzki Posted March 13, 2012 Share Posted March 13, 2012 Have you checked the trans fluid level and condition? start with the easiest(and cheapest) Quote Link to comment Share on other sites More sharing options...
andz222 Posted March 13, 2012 Author Share Posted March 13, 2012 will check that today and see Quote Link to comment Share on other sites More sharing options...
Josh Posted March 13, 2012 Share Posted March 13, 2012 Sounds like the clutch slipping to me. Quote Link to comment Share on other sites More sharing options...
Robzki Posted March 13, 2012 Share Posted March 13, 2012 Sounds like the clutch slipping to me. Go and post in the Manual transmission section of the forum, we have no need of your posting prowess here in the auto section. Quote Link to comment Share on other sites More sharing options...
andz222 Posted March 13, 2012 Author Share Posted March 13, 2012 its an automatic not manual Quote Link to comment Share on other sites More sharing options...
Robzki Posted March 13, 2012 Share Posted March 13, 2012 "To check the level, drive the car for 10 - 15 miles but not too hard. Park on level ground, leave the engine running for the whole checking process, this is most important other wise your will get a false high reading. With your foot on the brake run through all gears passing through neutral a few times, this ensure the fluid is dispersed round the system and not sitting in the sump. Place the selector in park. Take out the dipstick wipe it, reinsert and check the level, it should be at or close to the high mark." - Terminator Quote Link to comment Share on other sites More sharing options...
andz222 Posted March 13, 2012 Author Share Posted March 13, 2012 thx robzki will def check that Quote Link to comment Share on other sites More sharing options...
Josh Posted March 13, 2012 Share Posted March 13, 2012 its an automatic not manual Sorry. I should have seen that. Quote Link to comment Share on other sites More sharing options...
Robzki Posted March 13, 2012 Share Posted March 13, 2012 No problem, also check that the fluid is a nice red colour and also doesn't smell 'burnt' its doubtful that this is the issue but well worth checking Quote Link to comment Share on other sites More sharing options...
