suprasize Posted March 12, 2012 Share Posted March 12, 2012 Ameteur question, but how easy is it? Seen it done before on some guys supra at whifbitz and it seemed very straight forward, however I dont want to do it wrong... Any write ups on here? Or is it so easy to do that its not really required haha. Oh, and before everyone gets excitable and says use the "Search" button, I have, many times, and im still unanswered . Thanks again, Dan Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted March 12, 2012 Share Posted March 12, 2012 Pretty easy: Let the Car settle over night or let the fuel pressure of if you've driven the car. Take the space saver Wheel out then the black cover you'll see several hoses conected. Remove all of them(hope you have no pressure on the system ) and the electrical connector. Now comes the "hardest" part as the big plastic "nut" is a pita to remove, at least on my car i lost the biggest amount of time with it. When it's of you can easily pull the hanger construction but be carefull as you have to twist and tilt it a bit to remove it. When the whole thing is out it's pretty straight forward disconnect and remove old pump insert new pump and connect everything back. Fit the hanger, big plastic nut, hoses and the electrical connector to the hanger and admire your work p.s. If you get a Walbro you'll have to solder the Walbro connector to the stock one. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted March 12, 2012 Share Posted March 12, 2012 http://www.mkivsupra.net/vbb/showthread.php?45647-How-to-change-a-Supra-fuel-pump heres a guide but looks as simple as canislupus explains theres photos on one of the pages too Quote Link to comment Share on other sites More sharing options...
Drew_flux Posted March 13, 2012 Share Posted March 13, 2012 just dont do the 12 volt mod. there is a thread on here somewere about using a relay correctly. Quote Link to comment Share on other sites More sharing options...
suprasize Posted March 13, 2012 Author Share Posted March 13, 2012 fitted now Thanks for the info Quote Link to comment Share on other sites More sharing options...
ashbuster Posted March 13, 2012 Share Posted March 13, 2012 just dont do the 12 volt mod. there is a thread on here somewere about using a relay correctly. whats that mean? can we just follow that guide ? Quote Link to comment Share on other sites More sharing options...
suprasize Posted March 13, 2012 Author Share Posted March 13, 2012 whats that mean? can we just follow that guide ? Heres the 12 v Mod dude http://www.mkivsupra.net/vbb/showthread.php?35949-12v-Fuel-Pump-Mod Quote Link to comment Share on other sites More sharing options...
ashbuster Posted March 13, 2012 Share Posted March 13, 2012 (edited) i dont need that do i mate i just swap my fuel pump on mine dont i? i have a jap spec but im bpu apart from pump and all i do is swap it over dont i? just want to add to this i dont need bigger injectors do i? Edited March 13, 2012 by ashbuster (see edit history) Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted March 14, 2012 Share Posted March 14, 2012 i dont need that do i mate i just swap my fuel pump on mine dont i? i have a jap spec but im bpu apart from pump and all i do is swap it over dont i? just want to add to this i dont need bigger injectors do i? no you don't need bigger injectors for BPU. BPU List 1) Aftermarket cat-back exhaust 2) Fuel cut defender 3) Updated fuel pump 4) Colder grade spark plug Anything else you add are extras Quote Link to comment Share on other sites More sharing options...
ashbuster Posted March 14, 2012 Share Posted March 14, 2012 pump will be fitted the weekend i have everything else plus a i-color boost controller shouldnt decat be on that list too Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted March 14, 2012 Share Posted March 14, 2012 pump will be fitted the weekend i have everything else plus a i-color boost controller shouldnt decat be on that list too i just assume most people who drives supra's would of got rid of the cat. But no you are right decat and maybe a restrictor ring unless you have a UK spec Quote Link to comment Share on other sites More sharing options...
ashbuster Posted March 14, 2012 Share Posted March 14, 2012 yeah that downpipe is defently not going back on Quote Link to comment Share on other sites More sharing options...
-Welsh-Stealth- Posted March 15, 2012 Share Posted March 15, 2012 yeah that downpipe is defently not going back on good man easy fitting walbro, 2 minutes connecting the new pump up. and 2 hours removing/refitting the big plastic ring holding it all in place! Quote Link to comment Share on other sites More sharing options...
ashbuster Posted March 15, 2012 Share Posted March 15, 2012 lol any tips for that part? i heard that its a pain Quote Link to comment Share on other sites More sharing options...
-Welsh-Stealth- Posted March 15, 2012 Share Posted March 15, 2012 perseverance& lot's of patients lol i got to it with a hammer& screwdriver(flathead)...it'll really seem like it won't wana move, just give it a bit of mong strength& try not to break the fins/teeth Quote Link to comment Share on other sites More sharing options...
Robzki Posted March 15, 2012 Share Posted March 15, 2012 try not to break the fins/teeth Quote Link to comment Share on other sites More sharing options...
ashbuster Posted March 15, 2012 Share Posted March 15, 2012 lol will be doing it saturday i think Quote Link to comment Share on other sites More sharing options...
ashbuster Posted March 18, 2012 Share Posted March 18, 2012 if any one is having second thought about this then i wouldnt worry, its an easy job and simple to do. soaked the black ring in wd40 and it screwed on most the way then tapped the rest Quote Link to comment Share on other sites More sharing options...
