Newly BPU'd and popping and loss of power on second turbo
Notts_TT
I've just read setting 12 on fcd is cars standard setting.
I'll turn it to 9 tomorrow and run it again :-)
Could a slight boost leak or something mess up afr readings ?
Thanks
If you had it on the stock setting it was probobly hitting the fuel cut dude
??? Not sure dude, but if I reset ecu and drive like miss daisy it runs at correct readings, as soon as I boot it once, it runs mega rich all the time ?
How have you got your figures dude that you quoted ???? Try the fcd but it always worth a power run to see how shes running
Sorry, a AEM afr gauge...
It runs all over, like I said if I reset ecu and drive super steady not hitting 2nd turbo it will idle at 14+ and cruise at 14 + but as soon as I boot it she idles at 11ish and cruises at 11ish...
Its driving me mad too...
Thanks
Guest Budz86
One of the VSV's stuck open? Guessing here but I've got a problem with an intermittent 2nd turbo and pretty sure that's what's causing it, not sure if that would cause funny AFR readings though? :search:
How old is the sensor dude ??? They dont last forever, when you get the popping sorted you should book a power run on a dyno like I said before, they willuse a much better / faster wideband sensor than the AEM one which is TBH pretty crap !"!!!
