Pig Posted March 11, 2012 Share Posted March 11, 2012 So those of you that spotted my previous thread: http://www.mkivsupra.net/vbb/showthread.php?262986-Gearbox-Failure&highlight=gearbox+failure I pulled the car out the garage yesterday as I wanted to look at what was involved in removing the gearbox. For a laugh I called my wife out, told her I had fixed it and we to drive it forward to let it make the lovely crunching noise again...only this time, it left a load of fluid and metal on the floor. After disconneting the plug at the back and pulling more bits of metal out, I am left with the following (see pics). So I have a few questions: 1. Can you tell what diff I have in there? (For the record, I think it is a UK Spec auto diff) 2. How do you remove it? And is it a job for the driveway or is it a job for a garage? 3. What diffs can I put in to replace it? Quote Link to comment Share on other sites More sharing options...
Scott Posted March 11, 2012 Share Posted March 11, 2012 Big case diff so if you suspect UK auto it's most likely correct. The diff cooler would support this also. Removing the diff is fairly straight forward. I can't think of any issues to swapping it over on your driveway. Unbolt the prop, unbolt the driveshafts and unbolt the mount. Quote Link to comment Share on other sites More sharing options...
Tyson Posted March 11, 2012 Share Posted March 11, 2012 I'll have a look at mine but it looks like the standard one. Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 11, 2012 Share Posted March 11, 2012 I'd personally take it to a garage, 2 hrs max on a ramp would see the old one out and a new one in. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted March 11, 2012 Share Posted March 11, 2012 (edited) Jeez, thats a mess... Hows does a failure like this happen? Just too much torque? Drag starts or abusive driving? Edited March 11, 2012 by Samurai 20V (see edit history) Quote Link to comment Share on other sites More sharing options...
D8MOA Posted March 11, 2012 Share Posted March 11, 2012 well thats a darn sight cheaper then a 6 speed gearbox to replace lol i did a uk diff last year at home in a few hours Quote Link to comment Share on other sites More sharing options...
Pig Posted March 11, 2012 Author Share Posted March 11, 2012 I think it happens with abusive driving. Much cheaper. Worryingly I bought a box from Japan but thankfully it fell through. Now I know how hard box's are to get, I am booking mine in for a rebuild as the synchro on 3rd is going. Quote Link to comment Share on other sites More sharing options...
Pig Posted March 11, 2012 Author Share Posted March 11, 2012 Right, I have decided I am going to take it off myself as I want to know what I need to order to replace it. Any advice? Or is it just a case of unbolt things until you can take it off? Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted March 11, 2012 Share Posted March 11, 2012 Right, I have decided I am going to take it off myself as I want to know what I need to order to replace it. Any advice? Or is it just a case of unbolt things until you can take it off? Repair Manual should help.. Good luck. http://www.mkivsupra.net/vbb/content.php?75-Suspension-Axle Quote Link to comment Share on other sites More sharing options...
Pig Posted March 11, 2012 Author Share Posted March 11, 2012 I'd personally take it to a garage, 2 hrs max on a ramp would see the old one out and a new one in. I WISH I had listened, was a massive effort to do on the driveway. well thats a darn sight cheaper then a 6 speed gearbox to replace lol i did a uk diff last year at home in a few hours I still need to rebuild the box but yeo, lots cheaper and more to the point, this means I should make the dragonball. So, the diff is out and its clear that the the back section and the insude needs replacing. Does anyone know how much the back section is and is it the same on all big diffs? Its clear that I have been running my UK Auto diff so I could obvously try to source another UK auto diff but I think that will be difficult to find. Can I buy just the internals of a TRD diff and put in mine? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 11, 2012 Share Posted March 11, 2012 Well that's a right mess Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 12, 2012 Share Posted March 12, 2012 At least you got it out im a great believer in doing things the easy way, my days of lieing on the floor with arm ache are long gone a trip to my local village garage and job done, plus a good check of everything else whilst its on the ramp Hope you didnt get oil on the block paving !! Quote Link to comment Share on other sites More sharing options...
Pig Posted March 12, 2012 Author Share Posted March 12, 2012 All over it, have tried to jet wash it off but you can still see it.... One really happy wife!!! This is the last bit of mechanical work I do on the car!! Have found a uk auto diff which is what I was running and loved that setup but want to consider a TRD diff, it's difficult to know! Does anyone know what is included with a TRD diff and how much they are? Quote Link to comment Share on other sites More sharing options...
Littler Posted March 12, 2012 Share Posted March 12, 2012 I think a lot of what you need is near the bottom of this page: http://www.mvpmotorsports.com/Templates/frmTemplateM7.asp?SubFolderID=210&SearchYN=N And I'd say get the installation kit as well. Hope that helps. Quote Link to comment Share on other sites More sharing options...
Pig Posted March 12, 2012 Author Share Posted March 12, 2012 Another question is, are the UK big auto diff's difference from J spec big auto diffs? Apart from the cooling? Quote Link to comment Share on other sites More sharing options...
JamieP Posted March 12, 2012 Share Posted March 12, 2012 Another question is, are the UK big auto diff's difference from J spec big auto diffs? Apart from the cooling? No such thing as a j-spec big auto diff mate, the j-spec autos only had small diff. Quote Link to comment Share on other sites More sharing options...
Pig Posted March 12, 2012 Author Share Posted March 12, 2012 No such thing as a j-spec big auto diff mate, the j-spec autos only had small diff. Thanks j Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted March 12, 2012 Share Posted March 12, 2012 John, I have the TRD auto diff on mine and its awesome. Same short final drive as is on yours but with the added bonus of alot more grip. Really impressed with mine. Quote Link to comment Share on other sites More sharing options...
Miguel Posted March 12, 2012 Share Posted March 12, 2012 (edited) So, the diff is out and its clear that the the back section and the insude needs replacing. Does anyone know how much the back section is and is it the same on all big diffs? Its clear that I have been running my UK Auto diff so I could obvously try to source another UK auto diff but I think that will be difficult to find. Can I buy just the internals of a TRD diff and put in mine? Hate to be the harbinger of doom, but I would get a professional to check that diff out if you're contemplating rebuilding it. There's a fair amount of damage to that diff and no doubt a fair bit of swarf has been mooning around inside it meaning it may require more parts than would make financial sense. You may also find you have swarf in the coolant pump and cooler which will either require flushing, or even better, replacing. Edited March 14, 2012 by Miguel (see edit history) Quote Link to comment Share on other sites More sharing options...
Pig Posted March 12, 2012 Author Share Posted March 12, 2012 Thanks mig. I had nearly made my mind up and that's done it. Put another uk auto diff on and be done with it. Cheap too at only 440 from a scrappy. Can then look to upgrade at a later date to TRD if I choose, although the car has loads of grip with the r888's. Thanks all for your help everyone, saved me hours of research and messing about. Anyone want to buy a diff, hardly used....since blown to bits http://img.tapatalk.com/5f939751-894f-b081.jpg Pic of some of the bits that come with it for free Quote Link to comment Share on other sites More sharing options...
Pig Posted March 12, 2012 Author Share Posted March 12, 2012 John, I have the TRD auto diff on mine and its awesome. Same short final drive as is on yours but with the added bonus of alot more grip. Really impressed with mine. Are you manual? I thought I was the only one that had cottoned on to that trick. Quote Link to comment Share on other sites More sharing options...
Drew_flux Posted March 13, 2012 Share Posted March 13, 2012 Damn that was a nasty noise. nothing a new case wont fix. now is the time to think about diff bush's, whilst its out an all. Quote Link to comment Share on other sites More sharing options...
