mestew87 Posted March 11, 2012 Share Posted March 11, 2012 Ok i have put this here as i thought this would be the best place to try and get some help on this matter. Car - Soarer JZZ30 1JZGTE I installed the emanage ultimate, i started the car after splicing then after the injector wiring just to make sure everything was still working and i could trace it all via the software which i can. My issue then happens with the ignition side, I have set all parameter to what they should be in the software but on the ignition tab the table for the firing is blank, I have tried inputing a value but it wont hold the value. I am running Version 2.20 software Quote Link to comment Share on other sites More sharing options...
CJ Posted March 11, 2012 Share Posted March 11, 2012 Send IanC a PM. He is top man on the e-manage Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 11, 2012 Share Posted March 11, 2012 If you're talking about the set up, there s no need to change it, and it only applies to map 2 anyway, and if you right click on the box you will get an option of none or the same value. Quote Link to comment Share on other sites More sharing options...
mestew87 Posted March 11, 2012 Author Share Posted March 11, 2012 I get the option to select a value but it wont allow the value to hold. The table doesnt identify what each column or row actually is either Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 11, 2012 Share Posted March 11, 2012 I get the option to select a value but it wont allow the value to hold. The table doesnt identify what each column or row actually is either Can you do a screen grab and post it up? as its not very clear what you mean, it doesn't sound like we are talking about the same thing, hold on, Quote Link to comment Share on other sites More sharing options...
mestew87 Posted March 11, 2012 Author Share Posted March 11, 2012 Ok the vehicle page is exactly like that however my ignition page is like this: Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 11, 2012 Share Posted March 11, 2012 Then i would suggest installing and reinstalling the software, as it sounds like there is a glitch. Quote Link to comment Share on other sites More sharing options...
mestew87 Posted March 11, 2012 Author Share Posted March 11, 2012 I will try that tomorrow, I have tried it on two laptops, One gives me the blank table as above, The other one does give information in the table however its just symbols like a character set is missing. We have checked the wiring and everything is as it should be. Does the EMU get its ignition pulse from the cranks sensor ? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 11, 2012 Share Posted March 11, 2012 (edited) It does sound like there is a software, or operating system incompatibility problem to me, have you got both the crank sensor and the RPM signal wired up? i could never get the crank sensor to provide an RPM signal to the EMU with the 2JZ, always used the taco input, 1JZ may be the same. Edited March 11, 2012 by Tricky-Ricky (see edit history) Quote Link to comment Share on other sites More sharing options...
mestew87 Posted March 11, 2012 Author Share Posted March 11, 2012 yeah both are connected, I am formatting one of the laptops now with a fresh install of xp and then will reinstall emanage on it to see if that helps any Quote Link to comment Share on other sites More sharing options...
mestew87 Posted March 13, 2012 Author Share Posted March 13, 2012 I reinstalled xp and emanage to the computer and now data data in the table. Still dont get any ignition have played around with jumper settings to a base set uup i found from the guys over in austrailia Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 13, 2012 Share Posted March 13, 2012 I reinstalled xp and emanage to the computer and now data data in the table. Still dont get any ignition have played around with jumper settings to a base set uup i found from the guys over in austrailia What does this actually mean? nothing in the ignition settings still? or it actually not firing? Quote Link to comment Share on other sites More sharing options...
mestew87 Posted March 13, 2012 Author Share Posted March 13, 2012 The ignition table is full but no spark when cranking. I had the car running with the ignition loom not connected and moved each connector over one at a time. Emanage channels 1-5 are able to be connected and the car still runs however when i swap channel 6 over it kills the engine, the car wired up as follows: Emanage Channel -> Car Cylinder: 1-1 2-5 3-3 4-6 5-2 6-4 Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 13, 2012 Share Posted March 13, 2012 Sounds like there is a wiring fault to me, or a problem with a coil pack once connected, which could indicate a trigger signal fault within the EMU or the coil. other than that, have you got theginn voltage setting at 5V or 12V, as i know the 2JZ prefers 12V. Quote Link to comment Share on other sites More sharing options...
mestew87 Posted March 13, 2012 Author Share Posted March 13, 2012 The voltage was set to 5v but I have had it set at 12v but made no difference. I am going to redo all the connections as a last go I will hard wire them all in to get by any issues with connections, I will also test each coil pack, what's th best way doing that Quote Link to comment Share on other sites More sharing options...
Ian C Posted March 14, 2012 Share Posted March 14, 2012 My IGN tab simply has: CH-1 -> 1 CH-2 -> 2 CH-3 -> 3 CH-4 -> 4 CH-5 -> 5 CH-6 -> 6 I wired up the unit according to firing order: EMU Ign CH-1 -> Pin B57 on Supra ECU (Igniter 1) EMU Ign CH-2 -> Pin B53 on Supra ECU (Igniter 5) EMU Ign CH-3 -> Pin B55 on Supra ECU (Igniter 3) EMU Ign CH-4 -> Pin B52 on Supra ECU (Igniter 6) EMU Ign CH-5 -> Pin B56 on Supra ECU (Igniter 2) EMU Ign CH-6 -> Pin B54 on Supra ECU (Igniter 4) Quote Link to comment Share on other sites More sharing options...
