the impossible crank pulley bolt
suprasize
Okay, ill give a brief run down on what's what, and hope one of you guys can point me in the right direction..
Okay, during a timing belt change (incl pulley, tensioner and belt), the crank pulley bolt has decided not to budge atall. The garage who have been working on her have pretty much tried everything.. powerful air guns, scaffold bars to lever the breaker bar, heat guns.. everhthing! But still! No movement! :-( what has been suggested is to cut the bolt off and rethread through the crank..
Has anyone had this problem before?
Has anyone used a company who can rethread the bolt? Seems very specialist.
Please post any advice you guys have.
So annoyed and fed up.
Thanks
Dan
Had the problem on a mates car, we used a torque multiplier.... We reckon it was close to 800 (not sure on the unit of measure but believe it should have been 259-300 ish) when the bolt finally decided to budge...
From what theyve said, they used the most powerful airgun snap on provide, and still it isn't budging. Its ridiculous. This car seems impossible.
Put the large breaker onto it with the scafolding pole and put it on the ground. Use the starter motor to free it off. Be sure to put it to the correct side etc.
There is obviously a lot of danger in this approach but common sense should prevail.
This! The bolt is not torqed to that level. Its the massive amount of locktite that need to be "broken" trough
Doing as scott said will most likely free it!
Well i dont know how big gun the biggest snap on is But i used a gun used when changing tyres on lorries. My impact Gun is huge and it made no differens But when i used the heavy duty one it broke free with ease. But you would need to remove all radiators as it take quite some space.
Good luck!
It will come off they need to lock the pulley as mentioned.
cutting the bolt off and re-threading is a mad decision, And not a job id like to take on, Imagine drilling it out while the crank/engine is in postion.
Id take it somewhere else if they cant get it off, dont let them cut the bolt ffs.
As said, it will come out with the locking tool without heat. You could use the biggest air impact type of gun there is, but unless its locked up it wont budge if it's a tight one. I have a had a couple now that local garages tried and gave up on, but I made a very basic tool to lock it via the threaded holes and they shifted. There is a guy on here who reckons you can lock it by using a cam pulley locking wedge tool.....all that torque through the belt and across the tensioner cant be good and if its a tight one the belt would just strip anyhow. Paul will have have a tool to lock the crank pulley I am sure.
