SupraD06 Posted March 10, 2012 Share Posted March 10, 2012 Hi guys, been stripping out the engine bay over the last few days getting it all painted up and changing parts as i go. But having taken out all the turbo pipework, and vac lines, ive now noticed that ive got quite abit of oil gathering around the cam covers. Im guessing this isnt just build up from being 15 years old? Is there gaskets under the cam covers which may have perished? And if so are they easy enough to replace? any advice would be great Cheers Heres how its looking at the minute: Link to comment Share on other sites More sharing options...
Rob W Posted March 10, 2012 Share Posted March 10, 2012 Yea there is a rubber gasket that goes round the each of each cover, as they get older they perish. There about 10 quid each, Paul whiffin would probably have them in stock. Not much to change over, just unbolting them and replace seal, make sure no crud/dirt falls in as you take the covers off tho. Link to comment Share on other sites More sharing options...
SupraD06 Posted March 10, 2012 Author Share Posted March 10, 2012 Cool, just been doing abit of a search and it seems that there are rubber washers under the bolts that hold down the covers, and when they start to perish they alloy play in the bolts, so it may be that i need to replace bolts/washers, and the two gaskets. I'll speak to Paul about it. Chhers for the reply. Link to comment Share on other sites More sharing options...
tomgeer Posted March 10, 2012 Share Posted March 10, 2012 Just try nipping them up a bit first, I read somewhere that they have a habit of working loose over time (sometimes even finger tight) mine was weeping a bit so gave it a slight nip up and no more leak Link to comment Share on other sites More sharing options...
ashbuster Posted March 10, 2012 Share Posted March 10, 2012 i had a little leak there too i decided to nip them up like tomgeer said, mine wasnt even finger tight so far so good Link to comment Share on other sites More sharing options...
SupraD06 Posted March 10, 2012 Author Share Posted March 10, 2012 Cool, will have a look tomorrow and see just how tight they are. Chris Wilson posted on another thread about being carefull that you dont over do them as it may crack the casting. Ive sent Paul a pm about replacing everything, and from what ive found the gaskets should be around £20 for the pair, and then whatever it costs for some new nuts and washers. Might just do a swap of all the old seals to make sure its sealing well. Cheers guys Link to comment Share on other sites More sharing options...
sideexitsupra Posted March 10, 2012 Share Posted March 10, 2012 Another possible reason could be the front seals on the cams. When we're they last done? Link to comment Share on other sites More sharing options...
SupraD06 Posted March 11, 2012 Author Share Posted March 11, 2012 No idea, the cars only just clocked 51000 miles, could look through the paperwork and check what was done at different services. Link to comment Share on other sites More sharing options...
