blitz i-color metal vac line tapping problem
ashbuster
hey guys
when i come to install the blitz i color there is a metal t-piece that needs to be tapped into the boost gauge line.
this is joined to a nylon pipe that runs to the controller and joins onto the back by a connector onto the short pipe on the back of the controller.
hard to explain but if you have seen a blitz boost controller you will understand.
the nylon pipe and connector and t-piece is missing, i think not many people use them and they link it another way and thats why these bits get lost.
its not a problem because most of these controllers i have seen are sold without these so the must be a better way to join it without these
would i be ok to run a 3mm silicone hose (vac hose) to this pipe on t he back of the controller and slide that nylon pipe inside it
the nylon pipe is tiny but fits snug inside
i was wondering if i would have a leak and if there was much vacuum here
im sure alot of people have fitted these and had these bits missing i think they get installed without them
any ideas? could i do what i said
Edited by ashbuster (see edit history)
hi mate ,the part in worried about is the nylon hose in the back of the controller
the inside diameter must be about 1mm-2mm at the most would be hard getting a t-piece for it because the original tpiece doesnt go inside the hose it goes around it
its hard to explain but the nylon hose goes inside the one end of the t-piece
my problem is getting this nylon hose to join to my silicone hose which i will have a t-piece on the end
i can slide the nylon hose inside the 3mm silicone hose and it fits nice and snug but would it leak?
im new to this so not sure how strong the vacuum would be and if it would be enough to make it leak or if it would be fine
hi mate
the pieces i dont have are circled in red in this pic
which is a nylon hose, a connector to connect the hose to the hose coming from the back of the controller, and the blitz t-piece
ive circled in blue the hose from the back which i need to connect to some 3mm hose somehow, it does fit nice inside the hose but i dont know if it would be ok like that.
most of these kits ive seen for sale 2nd hand have these bits missing too so i wondered how others fit it?
i think these bits are usually kept on the car
