baldy Posted July 31, 2005 Share Posted July 31, 2005 had the trans apart today as the bearing in the pump had spun out of the casing and stuck on the converter. has any1 else experienced this? anyway got the new pump casing from toyota £125 not so bad i think just a bit worrying when you have to start taking clutch's apart to get thigs back together,but all seems cool, its nice having some power again,been off road 4 about 6weeks now Quote Link to comment Share on other sites More sharing options...
paul mac Posted July 31, 2005 Share Posted July 31, 2005 what was the general condition like inside the box and what miles have you done Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 31, 2005 Share Posted July 31, 2005 Monkey Mark had this with an auto box he brought to me. Convertor neck was badly machined on an aftermarket hi-stall convertor, from memory. Quote Link to comment Share on other sites More sharing options...
MONKEYmark Posted July 31, 2005 Share Posted July 31, 2005 had the tc put back in car and was no good, if you held on foot brake and try build revs up it would go to 3000 then drop to zero then back up to 3000. so got a new tc and all is well. chris fitted me a new gearbox filter. the old tc is in shed and needs to be sent back for a re stall. chris can you get a new pump as my spare gearbox needs one? Quote Link to comment Share on other sites More sharing options...
baldy Posted August 1, 2005 Author Share Posted August 1, 2005 box generally looking good, has about 65000miles on it, it was ok till i did some left foot brakin full throttle launches then the pump bearing said thats enough of that but all seems ok,apart from round the pump case is an 'o' ring but toyota couldnt help on this any one know a part number for this,just incase it starts to leak cheers baldy Quote Link to comment Share on other sites More sharing options...
