Guigsy Posted March 7, 2012 Share Posted March 7, 2012 Hi all My car is currently at garage786 In Leicester with ash. I had it there for a few issues mostly that it wouldn't start. Or more accurately it won't fire up more than half a second before it cuts out. Ash has done a great job so far and tried everything he can think of. But it won't start. Ryan couldn't sugest anything ether. All that's left is for him to try the ecu. Ash runs an aem on his car but his is a newer version than mine so my map won't transfer over. So. Does anyone have the older aem I could borrow to test. Or does anyone have one laying arround they are not using. My only other option is to go syvecs which is fine. But the £'s are tight enough as it is Quote Link to comment Share on other sites More sharing options...
imi Posted March 7, 2012 Share Posted March 7, 2012 would it not be cheaper to put the stock ECU back in the car in order to see if it can start? Quote Link to comment Share on other sites More sharing options...
Guigsy Posted March 7, 2012 Author Share Posted March 7, 2012 When I was speeking to ash if I remember correctly he didn't think that would work. Not sure why. Quote Link to comment Share on other sites More sharing options...
JamieP Posted March 7, 2012 Share Posted March 7, 2012 Sounds like its packed up, AEM V1's are known to fail. Only option would be to see if Ryan has a base map for your size injectors on a AEM V2 and try ash's ECU, trouble is you will be paying for ash's and Ryans time and will still end up buying a new ecu on top. Another option might be to send the AEM V1 to be checked, I think DanT is still the AEM UK agent. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted March 7, 2012 Author Share Posted March 7, 2012 Yeah. dan is not far from me. I had seen iffy things for aem but wasn't sure which version it was I had. I'm just looking to try and rule out the ecu being the problem. But in pretty sure its going to be anyway Quote Link to comment Share on other sites More sharing options...
JamieP Posted March 7, 2012 Share Posted March 7, 2012 If Ash has not already tried check the ecu is synced showing "ON" lots of people seem to have had starting problems because of the cam sensor, the aem needs a very good signal, I read people talking about grinding down the cam sensor to lessen the gap between the cam and the cam sensor magnet. Quote Link to comment Share on other sites More sharing options...
Abz Posted March 7, 2012 Share Posted March 7, 2012 Jamie does have a very good point about paying for Ryan & Ash's time & it still being an ECU issue. I think I remember reading threads where the board needed re-soldering? I know AlexM had a nightmare with them. Worth putting a wanted Ad incase this one isn't seen? Quote Link to comment Share on other sites More sharing options...
Guigsy Posted March 7, 2012 Author Share Posted March 7, 2012 I never seem to have much look with wanted threads and this thread has already thrown up things to try... Just pmed Ryan about syvecs too Quote Link to comment Share on other sites More sharing options...
Abz Posted March 7, 2012 Share Posted March 7, 2012 I never seem to have much look with wanted threads and this thread has already thrown up things to try... Just pmed Ryan about syvecs too Think some awesome GB's on Syvecs are going on at the moment too! Quote Link to comment Share on other sites More sharing options...
Guigsy Posted March 8, 2012 Author Share Posted March 8, 2012 Yeah. I can't wait around for a group buy to go through though. Quote Link to comment Share on other sites More sharing options...
AshBhp Posted March 8, 2012 Share Posted March 8, 2012 When I was speeking to ash if I remember correctly he didn't think that would work. Not sure why. Hi Adam, i need to know what injector you have and are they low or high impedance? You have yellow inj in standard fuel rail, which i think are Sard 650cc injectors high imp, can you confirm from previous owner. Mean while i see if i can borrow a J spec ECU from Keron. Quote Link to comment Share on other sites More sharing options...
AshBhp Posted March 8, 2012 Share Posted March 8, 2012 If Ash has not already tried check the ecu is synced showing "ON" lots of people seem to have had starting problems because of the cam sensor, the aem needs a very good signal, I read people talking about grinding down the cam sensor to lessen the gap between the cam and the cam sensor magnet. She does sync mate, i've tested alarm, cam, crank sens and ignitor pack all OK. So does point to AEM ecu, just need to be sure. lol. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted March 8, 2012 Author Share Posted March 8, 2012 I don't have the old owners details any more unfortunately. But the sard site says they are high imp yep. I'll call Ryan about a syvecs tonight.... Weather is getting nice again. Want the car back and I know ash is fed up of pushing it Stroud the place Quote Link to comment Share on other sites More sharing options...
johnny g Posted March 8, 2012 Share Posted March 8, 2012 I don't have the old owners details any more unfortunately. But the sard site says they are high imp yep. I'll call Ryan about a syvecs tonight.... Weather is getting nice again. Want the car back and I know ash is fed up of pushing it Stroud the place Do it. You'll end up with a car that drives better and more than likely produces more power! Quote Link to comment Share on other sites More sharing options...
