Slicknick Posted March 7, 2012 Share Posted March 7, 2012 Hi Guys, i did try searching but no luck, does anyone have any info on wiring the HKS FCD onto a vvti supra? Is it different wires on the ecu or is it the same? Many Thanks. Link to comment Share on other sites More sharing options...
ashbuster Posted March 7, 2012 Share Posted March 7, 2012 i would like to know this too theres a guide here http://www.mkiv.com/techarticles/fcd/fcd.htm but i dont know if pre-vvti and vvti wired the same? Link to comment Share on other sites More sharing options...
merckx Posted March 7, 2012 Share Posted March 7, 2012 but i dont know if pre-vvti and vvti wired the same? They aren't the same. http://www.mkivsupra.net/vbb/showthread.php?35919-ECU-Pinouts Link to comment Share on other sites More sharing options...
ashbuster Posted March 8, 2012 Share Posted March 8, 2012 any ideas how to find out what wires are what from our ecu's mine is a jap auto twinturbo 1996 facelift pre-vvti ive looked on that thread and noticed theres a jap on there but doesnt say if its facelift or not and it says they could be different somewhere i read (might have been that thread) Link to comment Share on other sites More sharing options...
Josh Posted March 8, 2012 Share Posted March 8, 2012 any ideas how to find out what wires are what from our ecu's mine is a jap auto twinturbo 1996 facelift pre-vvti ive looked on that thread and noticed theres a jap on there but doesnt say if its facelift or not and it says they could be different somewhere i read (might have been that thread) I've seen a guide before showing all the connections to the ECU and what they are. I have a guide saved at home showing how to set up the Thor FCD and a general one for setting up an EBC. If you don't find it and no one posts up, I'll post it up when I get home Link to comment Share on other sites More sharing options...
ashbuster Posted March 8, 2012 Share Posted March 8, 2012 nice one bud Link to comment Share on other sites More sharing options...
Josh Posted March 8, 2012 Share Posted March 8, 2012 This might be of help; http://www.mkivsupra.net/vbb/showthread.php?232824-J-Spec-Engine-Harness-Connector-Details This is even better; http://www.mkivsupra.net/vbb/showthread.php?35919-ECU-Pinouts Link to comment Share on other sites More sharing options...
ashbuster Posted March 8, 2012 Share Posted March 8, 2012 (edited) found it here bud http://mkiv.supras.org.nz/specs.htm link was from this http://www.mkivsupra.net/vbb/showthread.php?145275-ECU-Pinouts-for-a-1996-facelift-TT&highlight=pre+vvti+ecu+pinouts lol didnt expect it to come up in a search but it has nice one josh will save that link i think ill use a multimeter to check from the 2nd wire from the sensor to the ecu just to make sure i have the right wire lol looks like its the 2nd wire on the sensor Edited March 8, 2012 by ashbuster (see edit history) Link to comment Share on other sites More sharing options...
EMPEROR Posted March 8, 2012 Share Posted March 8, 2012 And this one is even better: http://www.2jzgarage.com/wp-content/uploads/2012/01/Supra_2JZGTE_VVTi_ECU_Pinouts.pdf Thanks to Dustin - 98SZR from supraforums.com.au Link to comment Share on other sites More sharing options...
ashbuster Posted March 8, 2012 Share Posted March 8, 2012 sorry for the highjack but it might help basically are we looking for the turbo pressure signal wire? and its the middle wire from this circled in red? and we just use a multimeter to trace the wire from there to the ecu? is this right i can get my hands on a multimeter inabout 10 mins so would this be right to garantee i have the right wire Link to comment Share on other sites More sharing options...
ashbuster Posted March 8, 2012 Share Posted March 8, 2012 i tried the above and i was getting results through a few wires my dad said it must be because its through a relay anyway it was the same colour wire as the pin62 which in the guide it said was the right one ive hooked it up and wired the live and ground , changed the setting to 9 everything is running as normal so i guess its worked lol? i am only set to 1 bar boost at the moment anyway because i have the 1st cat still in place , needs doing in a garage installed it ready as i guess it wont hurt Link to comment Share on other sites More sharing options...
