help ABS actuator 1997 toyota supra VVTI
Guest supradri
Guest supradri
hi need help on this ABS pump I bought this pump second hand from Japan I have problems connecting the Brake lines to this pump dont have any information
where to connect each line as you can see in the picture have 6 connection I dont know wich connections is for fwd tires and rears tires I appreciate very much you help
thanks in advance
straightsix, that is not the correct one. On facelift models rear left and right brake lines are on one channel.
supradri is your Supra facelift? If not, it wouldn't work straight in. Plus there are two actuators 44510‑14090 and 44510‑14100... Which one did you buy? And what exactly are the specs of your car?
Guest supradri
I have the 44510-14100 my car is American spec before none turbo but I swap to twin turbo 1997 VVTI engine and all the wiring to J spec now I can not conect my old ABS actuator because I change my engine room wire too I bought this ABS from Japan this one can plug on my new wire, what i need is some information about the 6 holes where can i connect the brake lines and master cylinder lines in this actuator any one who own the same pump can help
thanks very much
