rg500 Posted March 6, 2012 Share Posted March 6, 2012 Hi there, Can anyone help, i put down the drivers side window tonight it was very slow at going down it got half way down and stopped, now it won't go back up only down very slowly, apart from the fuses what could it be. as there is obviously still power there. Thanks. Quote Link to comment Share on other sites More sharing options...
keron Posted March 6, 2012 Share Posted March 6, 2012 Mech has prob failed....there are cables that drive the window up and down, due to wear, they fray and get caught/snap so a new window mech will be needed.....prob one of the most common things to go on them....i have brand new ones in stock if needed....take the door card off and have a closer look... Quote Link to comment Share on other sites More sharing options...
SilentAgro Posted March 6, 2012 Share Posted March 6, 2012 Mine went on Sunday. I'm sure you can get a cheaper mechanism than me. I got it from a main dealer £75 for it. Quote Link to comment Share on other sites More sharing options...
rg500 Posted March 6, 2012 Author Share Posted March 6, 2012 Thanks for the reply Keron, Just out of curiosity how much are the mechs delivered and are they easy to install, and what am i looking for when door card is off. Many thanks. Quote Link to comment Share on other sites More sharing options...
keron Posted March 6, 2012 Share Posted March 6, 2012 Ill get you the price in the morning...at home now...once you take the door card off, you should be able to see the mech, and a cable running verticle roughly in the middle of the door...it should be nice and tight, if not then its prob broke. Have a closer look where the cable goes to as it can frey and get jammed....might be worth checking if you have power comming to the switch too ( if you cant see a problem with the mech) Call me around 10ish if you like in the morn, if you need the mech i can get you one out same day if booked before 11. For next day del. Quote Link to comment Share on other sites More sharing options...
rg500 Posted March 6, 2012 Author Share Posted March 6, 2012 Thanks Keron. Will check in the morning weather permitting meant to be chucking it down here most of the day. So if you could get me a price sorting in the meantime I would be grateful. Many thanks. Quote Link to comment Share on other sites More sharing options...
