spidermonkey Posted March 5, 2012 Share Posted March 5, 2012 Hi all, while doing some routine maintenance I have decided the rad cap needs to be changed, while removing the old cap the spring loaded seal has perished and has dropped the front guide into the radiator. I have tried to grab hold of the offending item with long nose pliers but due to it being almost exactly the same size as the rad opening I have failed miserably, my question is how can I remove the said object, can I leave it in there or will I be able to flush it through the system without it getting stuck in the internals. Any help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 5, 2012 Share Posted March 5, 2012 It wont flush out, if you look inside the rad you'll see why. Best persevere and try and get it out, but if you left it in there it wouldnt go anywhere. Quote Link to comment Share on other sites More sharing options...
spidermonkey Posted March 6, 2012 Author Share Posted March 6, 2012 I'll have another go at removing this in that case, thanks for the answer. Quote Link to comment Share on other sites More sharing options...
Josh Posted March 6, 2012 Share Posted March 6, 2012 Are you just changing the cap or the coolant as well? If the coolant as well, then take the rad out and turn it upside down to make it easier. Quote Link to comment Share on other sites More sharing options...
spidermonkey Posted March 7, 2012 Author Share Posted March 7, 2012 I may have to go down that route, thanks for the answer. Quote Link to comment Share on other sites More sharing options...
Scott Posted March 7, 2012 Share Posted March 7, 2012 Is it a hoop? If so get a wire coat hanger and make a hook (or other wire). If not then a set of mechanical fingers will probably be your best bet. Quote Link to comment Share on other sites More sharing options...
David P Posted March 7, 2012 Share Posted March 7, 2012 A dod of silicone on the end of a pencil and Bob's your dad. Quote Link to comment Share on other sites More sharing options...
spidermonkey Posted March 8, 2012 Author Share Posted March 8, 2012 Its a solid piece of plastic with no hole, the big problem is that it's almost the same size as the hole it needs to go through so it needs to be dragged through, long nose pliers don't seem to be up to the job as I can't get enough grip! Thanks for the ideas though Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 8, 2012 Share Posted March 8, 2012 This may sound bonkers but if you can get it with long nose pliers and hold it right up in the neck of the rad and then use long nose mole grips to properly grab it, use one of those mini snap on style blow torches and heat up the plastic to soften it which should let you pull it through the hole. Quote Link to comment Share on other sites More sharing options...
spidermonkey Posted March 8, 2012 Author Share Posted March 8, 2012 Not bonkers at all, I like your thinking, do you have an engineering background per chance Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 8, 2012 Share Posted March 8, 2012 Not bonkers at all, I like your thinking, do you have an engineering background per chance Since leaving school many moons ago Dont go to mad though and melt the rad and have a bottle of water handy incase the plastic sets on fire Quote Link to comment Share on other sites More sharing options...
spidermonkey Posted March 8, 2012 Author Share Posted March 8, 2012 Will do, cheers buddy Quote Link to comment Share on other sites More sharing options...
