supradibbs Posted July 30, 2005 Share Posted July 30, 2005 guys please help when the car was dynoed last week on the dyno pack the car was shaking it self to bits with what looked like a warped discs but i have checked it today with the wheel of up to 40 and it runs stright and true but on the road on the way back after the dyno it was vibrating heavily at 80 :thumbdown i have checked the bushes on the diff etc etc can see any play. Is it possiable something has been bent by the dyno bear in mind it was not the roller type dyno As i say it has only been doing after that run please help kinnda concerend Link to comment Share on other sites More sharing options...
chilli Posted July 30, 2005 Share Posted July 30, 2005 its possible that you've got some play in the wheel bearing OR a bent half shaft (seems unlikely) ? Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted July 30, 2005 Share Posted July 30, 2005 are you sure u didnt knock any wheel weights off when taking off moving them about? Link to comment Share on other sites More sharing options...
Robert Posted July 30, 2005 Share Posted July 30, 2005 checked the wheel nuts are tight? i felt that wobble when my wheel fell off Link to comment Share on other sites More sharing options...
Chipmunk Posted July 30, 2005 Share Posted July 30, 2005 I had those symptoms when the front n/s wheel turned out to be buckled Link to comment Share on other sites More sharing options...
supradibbs Posted July 30, 2005 Author Share Posted July 30, 2005 god dont go ther at over 500 a wheel Link to comment Share on other sites More sharing options...
chilli Posted July 30, 2005 Share Posted July 30, 2005 What sort of dyno was it then? It seems pretty unlikely that your wheel got buckled to me unless it was manhandled! Does the vibration get worse under acceleration or braking, worse when cornering, worse at speed or always roughly the same? Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted July 30, 2005 Share Posted July 30, 2005 sounds like prop shaft rubbers to me..can you drive through it or slow down to stop it??? Link to comment Share on other sites More sharing options...
supradibbs Posted July 31, 2005 Author Share Posted July 31, 2005 yeah below 80 is fine went up to 120 and it seemed better i think but was a bit busy spanking a scooby Link to comment Share on other sites More sharing options...
chilli Posted August 1, 2005 Share Posted August 1, 2005 lol sounds like it would come back at 160mph too then Propshaft sounds like a good candidate doesn't it, as supraloopy mentioned, it's probably the most likely thing I guess. Link to comment Share on other sites More sharing options...
supradibbs Posted August 1, 2005 Author Share Posted August 1, 2005 would explain alot maybe the touque of the dyno????? Link to comment Share on other sites More sharing options...
chilli Posted August 1, 2005 Share Posted August 1, 2005 hmmm I wouldn't have thought that would affect the torque reading much, if at all, but I could be wrong as I'm no expert. Did you get an unexpectedly high or low reading then on the dyno? Link to comment Share on other sites More sharing options...
