tomgeer Posted March 3, 2012 Share Posted March 3, 2012 As above, I bought this years ago but probably won't ever get round to fitting it so anyone prepared to give me £110 can have it (delivered to UK). Includes the wiring harness that'll need splicing in to the loom (see photo), theres loads of info on the site on how to wire it in. Info taken from Apexi site: Piggyback Fuel Computer Modifies air-flow meter signal (pressure signal in some vehicles) to optimize fuel-air ratio; Vacuum Fluorescent Display (VFD). The second-generation SAFC is a fuel computer that adjusts fuel/air ratio by modifying the air-flow meter/MAP sensor signal. The SAFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The SAFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %. Link to comment Share on other sites More sharing options...
tomgeer Posted March 7, 2012 Author Share Posted March 7, 2012 Sold Link to comment Share on other sites More sharing options...
