Towing eye ideas?
Parry_10
I don't think that will be possible with mine as the fmic takes up all the gap in the middle of the do luck bumper
You dont have to put it there, just a small hole in the doluck that a tow eye screws into, when i had a doluck on the red car i had this.
Mines also covered but i have a tow hook in my car and the tools to remove my bumper just in case, it's only 15 minute job so not bad TBH. I'm going to look into a rear one and see if anything can be done with my trial rear.
Jamie, im guessing that your bolted onto the frame work that used to hold the crash bar?
That yellow supra is stunning, any more info on it?
It's one of Ebrahim Kanoo's I believe, more info/pics here - http://www.s2ki.com/s2000/topic/874842-one-badass-supra-1500-rwhp
http://img807.imageshack.us/img807/5558/toyotasupraorange14.jpg
http://img684.imageshack.us/img684/5329/toyotasupraorange8.jpg
Can I just ask, are the ones that are bolted on Illegal, as in classed as dangerous to pedestrains in an accident
Personally I don't like the look anyway, but I understand they are needed for practicality etc
I like the idea of a screw in one like on normal cars, would it be posible to cut the threaded part from a Breaker and weld that to the chassis somewhere and then you would just need a small circular hole to put the threaded eye through the bodywork
When in normal daily use you could have a colour coded rubber gromet too fill in the hole
Edited by DodgyRog (see edit history)
