Fitting electrical fan - help
RHochreuter
Hi guys,
How should an aftermarket electrical fan be connected?
I've recently purchased an electrical fan for my radiator, but i'm not 100% sure on how to connect the wires.
The stock fans consist of the big viscosis fan and the small electrical - both are now removed.
Can i simply connect my new fan to wiring from the small stock electrical fan?
Thanks
You will need a thermostatic switch to trigger the fans when the engine reaches a set temperature, if you wire them up to the small fan wiring via a relay, they will only switch on when your running the air con, or over a certain temp, however i am not sure without looking at the manual if that temp is over normal running temp, but i suspect it is, anyway its not the way to go really, the first option is the best.
Sometimes i wonder why i bother!
Edited by Tricky-Ricky (see edit history)
