Samurai 20V Posted March 3, 2012 Share Posted March 3, 2012 Hi.. Need some advice. I sat in a Supra that has a brand new ORC twin plate, clutch is silent on idle with the pedal depressed. When you press the pedal, there is a horrible scraping/rattling noise that comes from the clutch.. Is that normal? The pedal pressure is very light, the clutch supposedly has only done 600kms.. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
Guest j2x Posted March 3, 2012 Share Posted March 3, 2012 strapless clutches will emit a very loud rattle under certain circumstances, pedal up in neutral at idle for example. they can also rattle with the clutch out, before the engagement point is reached drivetrain vibrations such as those caused by large cams or a solid flywheel will exacerbate this (standard flywheel is dual mass which dampens a lot of vibration) os giken clutches for example are strapless, not sure about orc specifically if it doesnt slip and it shifts gear ok then the adjustment is probably fine. ask the owner if its a strapless clutch. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted March 3, 2012 Author Share Posted March 3, 2012 Thanks for the reply, I have some video of the noise, will upload shortly.. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted March 3, 2012 Author Share Posted March 3, 2012 (edited) Check video at 2:15secs.. Edited March 3, 2012 by Samurai 20V (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest j2x Posted March 3, 2012 Share Posted March 3, 2012 were you in neutral and just pressed the clutch pedal? hard to tell from that cos the actual sound is so short, but the second brief burst sounds a bit like mine when it rattles the first brief burst of noise sounded more like a grind but if you werent putting it in gear then it obviously wasnt id say its probably ok, as long as it shifts ok and the clutch holds if you buy it i would definitely remove that hks mushroom of death airfilter though, they dont filter very well Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted March 3, 2012 Author Share Posted March 3, 2012 were you in neutral and just pressed the clutch pedal? hard to tell from that cos the actual sound is so short, but the second brief burst sounds a bit like mine when it rattles the first brief burst of noise sounded more like a grind but if you werent putting it in gear then it obviously wasnt id say its probably ok, as long as it shifts ok and the clutch holds if you buy it i would definitely remove that hks mushroom of death airfilter though, they dont filter very well That was with the clutch down in neutral.. The first burst was me pressing the pedal and then letting go. 2nd was pedal all the way down. It took into gear fine.. I am gonna test drive the car soon, will see if it changes properly.. Hell of racket, people must think the car is broken with that noise.. The HKS filter is the first thing to go after the crap FRP bonnet and fenders.. Quote Link to comment Share on other sites More sharing options...
hodge Posted March 3, 2012 Share Posted March 3, 2012 I have an ORC twin plate in mine and it sounds horrendous. It's exactly as you explained. It is normal yes. The rattle when you press the pedal becomes quieter when the car is very hot but it then develops a rattle from the flywheel when the clutch is not pressed and the car is at idle. Very strong clutches though. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted March 3, 2012 Author Share Posted March 3, 2012 I have an ORC twin plate in mine and it sounds horrendous. It's exactly as you explained. It is normal yes. The rattle when you press the pedal becomes quieter when the car is very hot but it then develops a rattle from the flywheel when the clutch is not pressed and the car is at idle. Very strong clutches though. Thanks Hodge, my first experience with a twin plate clutch, I got very worried when I heard it.. Is there any multi plate clutch that is relatively quiet? Quote Link to comment Share on other sites More sharing options...
JamieP Posted March 3, 2012 Share Posted March 3, 2012 Wow, thats a loud clutch, RPS triple makes no rattle at all. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted March 3, 2012 Author Share Posted March 3, 2012 Wow, thats a loud clutch, RPS triple makes no rattle at all. Yeah, I thought the same... The guy told me it was brand new, I thought it had been installed wrong.. Quote Link to comment Share on other sites More sharing options...
CarlT67 Posted March 3, 2012 Share Posted March 3, 2012 Thats the same clutch I had on my Single I think, sounded like that whenever you press the clutch pedal down an it wasn't biting. It had a serious bite point though learning the clutch was quite fun. Quote Link to comment Share on other sites More sharing options...
add heywood Posted March 4, 2012 Share Posted March 4, 2012 Yep, all fine there mate. Another one with the same clutch as Hodge, noisy as hell. Expect to tell all passengers who don't know about cars that your car is fine and not about to blow up. As said the biting point is quite savage on mine... Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted March 4, 2012 Author Share Posted March 4, 2012 Thanks mates, that solves that issue.. Quote Link to comment Share on other sites More sharing options...
