Jimmy James Posted March 2, 2012 Share Posted March 2, 2012 I have a grinding noise in the back passenger wheel and it seems I be getting worse each day.. I'm guessing it's the wheel bearing and can't find one anywhere other than mill auto parts for £102/each. Is there anywhere cheaper to get a couple from? Also need to find some uk pads, same place does them for £50 for all four corners but thought this was a bit cheap. Any help is appreciated, thanks. Link to comment Share on other sites More sharing options...
Dnk Posted March 2, 2012 Share Posted March 2, 2012 (edited) Toyota could be worth a call .....or perhaps not in this case, £229 inc vat retail + £55 for the seals !! Are you sure its wheel bearing and not worn out brake pads down to the metal ? Edited March 2, 2012 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
bradleyh_15 Posted March 2, 2012 Share Posted March 2, 2012 Try hear http://www.importcarparts.co.uk/parts.asp?cat=89 That's where I got my last one from still going strong 4 years on Link to comment Share on other sites More sharing options...
Jimmy James Posted March 2, 2012 Author Share Posted March 2, 2012 Toyota could be worth a call. Are you sure its wheel bearing and not worn out brake pads down to the metal ? Brakes look good condition so pretty sure it's the wheel bearing, but brakes are squeeking alot so I assume they've glazed over or something.. I'll check with Toyota but probably more expensive there. Thanks. Link to comment Share on other sites More sharing options...
jimojameso Posted March 2, 2012 Share Posted March 2, 2012 The rear bearings usually always knacker the hub flange when they go aswell. Bearings are £70 Hub flange is £160 Link to comment Share on other sites More sharing options...
Jimmy James Posted March 2, 2012 Author Share Posted March 2, 2012 Wow Toyota is £192 per bearing.. I've found a place that will do the lot for £305 so already ordered. Thanks for the info guys. Link to comment Share on other sites More sharing options...
Lude Posted March 2, 2012 Share Posted March 2, 2012 Ebay ones are around 60 and few on here have them and have lasted years Link to comment Share on other sites More sharing options...
Paul Whiffin Posted March 2, 2012 Share Posted March 2, 2012 I have the bearings in stock http://whifbitzperformancetuning.co.uk/toyota-supra-supra-diffgearbox-axle-c-42_47_824.html Pads as well http://whifbitzperformancetuning.co.uk/toyota-supra-supra-brake-parts-toyota-parts-c-42_47_76_939.html Link to comment Share on other sites More sharing options...
Jimmy James Posted March 2, 2012 Author Share Posted March 2, 2012 I have the bearings in stock http://whifbitzperformancetuning.co.uk/toyota-supra-supra-diffgearbox-axle-c-42_47_824.html Pads as well http://whifbitzperformancetuning.co.uk/toyota-supra-supra-brake-parts-toyota-parts-c-42_47_76_939.html Pm'd mate. Link to comment Share on other sites More sharing options...
Nic Posted March 2, 2012 Share Posted March 2, 2012 Brakes look good condition so pretty sure it's the wheel bearing, but brakes are squeeking alot so I assume they've glazed over or something.. Could also be a seized rear brake caliper. Link to comment Share on other sites More sharing options...
