How do you achieve over run?
Andrew
Guest Terry S
If it's done properly it will be because of the fuel over run shut down, on a programmable ECU.
If it just all show & no go " MAX POWER STYLE" then it will just be a spark plug in the exhaust.
This can naturally occur on highly tuned cars as unburnt fuel is ignited by the heat of the exhaust etc.
This also happens when you are running antilag like on WRC cars but this is very bad for the turbos and is only supported by some aftermarket ECU`s.
Hope this helps,
Regards
Wez
PS you could always by a flamer kit which works off a switch under the throttle, just for looks though and offers no performance gain.
Antilag is bad for the turbos yes :)
Its ok for WRC teams who have alot of funding but for the average driver it can be costly, ok for track fun but does decrease the life of the turbo.
I got a friend who runs antilag on a scooby, he gets mental launches due to boost being available at standstill but he doesn`t use it very often.
For a decent programmable ECU you are looking upwards of 1000 quid.
Guest Terry S
ALS is not too kind to turbo's. Fuel Over run is OK. Tough on exhausts though.
A programmable ECU will cost between £3-10k to install & map.
Funny you should say that, my MKIII (decat) poped and gurgled more than my MKIV (decat), I put it down to the MKIII being old, having lots of miles on the clock, and thought the fueling was slightly out. Over fueling maybe?
I know your MKIII is highly modded Adam, do you have a programmable ECU too?
Just save yourself all the bother and get the flamer kit...... Great gun... and at £120...well.... Cheaper option to the ECU.
:flame Dev
http://www.chill-ville.co.uk/3.jpg
Mine only works though when i'm off the accelerator whilst changing gear from 3rd gear onwards... It don't work in first and second..
Craig,
Its always funny when you see the flames go higher than the rear of your spoiler when looking through the rear view mirror doing 90+.
Guest Terry S
Just get a SAFC or similar & richen it up on part throttle, If you dump enough fuel into a hot exhaust you'll get your snap-crackle-pop. WHY do you want the car to do this. Mine shoots out 6ft flames & I hate it!
It's not so much the flame it's the noise.
There's a Diablo and a TVR where I live that do this, makes all the hairs stand up on my neck when ever I hear them. The Diablo is insane, it pops and crackles on idle :)
I'm one of those Supra owners that has the window open in sub zero temperatures just so I can hear the decat. I know I'm not the only one ;)
What'SAFC?
SAFC and big injectors at the moment, currently trying to decide between an E-manage and spending three times as much on an AEM ECU. It was ditching the backbox that made it sound mean though.
Originally posted by Wez
I am also looking at the AEM at the moment, but it doesn`t really seem to be plug and play on the J-Spec :(
I know Paul Whiffin spent a shed load of money getting the AEM mapped on his J-Spec. I should imagine he would have some base maps available for J-Spec's that should make things a lot easier than mapping it from scratch. You'll probably still be looking at a lot of money on mapping though. Anyone have any idea's as to how much? Thinking I'll go for the greddy emanage when I get hybrids.
I didn't spend a shed load of money mapping my AEM, I spent a shed load of time getting it all to work properly though, mainly because I was the first to install it on a J-spec so there were no base maps available, had to start from scratch. The E-manage will be far easier to set-up but then its never going to be as good as a mappable replacement ECU.
