spider2123 Posted March 1, 2012 Share Posted March 1, 2012 As above , has anyone ever tried a transplant to a mk4 supra? I have read that it is a brilliant set up. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted March 1, 2012 Share Posted March 1, 2012 The Supra's suspension is brilliant. Quote Link to comment Share on other sites More sharing options...
spider2123 Posted March 1, 2012 Author Share Posted March 1, 2012 I know this but I read that round the track it is very special. Just want to know if the setup can bet done Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted March 1, 2012 Share Posted March 1, 2012 I got a soarer sitting, that has that electronic suspension, are they worth much? Quote Link to comment Share on other sites More sharing options...
garethr Posted March 1, 2012 Share Posted March 1, 2012 (edited) The air suspension (UZZ31 model) and the "active" suspension (UZZ32) are completely different. Given the fact that the Supra uses the Soarer chassis, it would probably be possible to transplant the hydraulic active suspension into a Supra.... and if you spent a fortune rebuilding all the components, and provided you could find room for the pump, and the reservoir, and the distribution block, and the sensors, and the ECU, and all the other gubbins, and if you could make it work on a car with different dimensions... then you'd probably wish you'd just bought a sorted UZZ32 and RyanG's TT 1UZ set up. Edited March 1, 2012 by garethr (see edit history) Quote Link to comment Share on other sites More sharing options...
garethr Posted March 1, 2012 Share Posted March 1, 2012 I got a Soarer sitting, that has that electronic suspension, are they worth much?In short, no. Quote Link to comment Share on other sites More sharing options...
spider2123 Posted March 1, 2012 Author Share Posted March 1, 2012 If you were going 1uzfe anyway, could you do a complete vehicle loom swap- and just tie up things like heater etc . Quote Link to comment Share on other sites More sharing options...
