The Wangan Supra
steve.m
  • Replies 1.4k
Would that flip plate be legal? Would be interested in doing that to mine if I get one. Amazing car though.
Cheers. Like Gaz said, if it's locked down whist on the road then it's fine.
cheers steve, yes that will do nicely. Just wanted to imagine mine with a grill on, take it that is the silver grill?
It's black but unfortunately I had to remove it to run a legal size plate on the flipper.
Proper example of a lovely modded Supra Steve. Lots of time and effort gone into it, yet still OEM bodywork etc. Just goes to show you..do it right and the results are amazing.
- - - Updated - - -
Love the plate too..! Well trick.
Thanks Jim. :)
  • 3 weeks later...
  • 1 month later...
Took a little trip to SRD towers yesterday to get my AEM AFR taken out which had a damaged sensor due to catching it on a speed bump as it was in a crap location. We welded a new collar in a better location and replaced the sensor with an NTK pinned straight to the Syvecs. This meant the last gauge in the dash was removed and as you may have figured, I like to keep things stock looking so we fitted a facelift clock in it's place as the hole was too big for the pre facelift one. Another little unique twist to the car. :D
We also replaced the oil and filter, replaced the spark plugs as they were getting on a bit and gave it a quick pre Dragonball check. The car is now ready for ethanol mapping on Wednesday next week. I will update with the results. :)
Cheers guys, looking forward to it myself. I don't think it will make much more power to be honest as the turbos are pretty much maxed out and the 1000cc injectors cant be far off either. :)
Time to get the tyres change to the old R888's for the dyno to destroy as it's going on the rollers this time, not a hub dyno... will be interesting!
