TT CPS / Oil Pump
Noz
Evening all,
I was wondering how the TT oil pump runs the TT CPS, you can swap the NA and TT pumps to enable using the TT CPS, I've read different places it uses a halls sensor, but others say its a crack trigger and isn't magnetic as the gap required for halls would be too low.
I've had a search and came up with different answers.
i dont know much about the n/a but the tt has a crank trgger star which may be why they have different pumps, now i dont know if the n/a has this or needs this with a dizzy.
i know the sensors crank and cam are magentic as this give problems with my aem fic,
hope that helps but im sure someone that knows for sure will be along, maybe change the title so it will get picked up a little better
Thanks mate that does help understand why the oil pump is needed.
The NA has a gear that has been ground into the original billet, and is connected to the dizzy giving each cylinder its spark, I can remove it and use a different sensor but I want to change the cams and there are no 2JZ cams with the dizzy gear on.
I can't understand why the cam sensor needs to be in the head, if the oil pump uses the 12 tooth gear trigger.
Is it so the ecu knows at wot point in the cycle the piston stroke is in?, surely the 6 point would only give tempo
I've not took a dizzy apart, so I wouldnt know if the sensor was in there. That would make sense if by removing the dizzy you also remove the stock sensor.
I need to take one apart and find out, or find someone else that knows.
it might show you in the manuals
Im still confused.
So 2JZGE:
Dizzy (spark output)------------------------------------Replace with VVti Waste spark coils
crank position sensor (gear beneath Dizzy)-----------Replace with TT oil pump
OEM NA CPS---------------------------------------------Replace with welding in TT sensor into head.
HT Leads-------------------------------------------------Replaced with coils from is300 - no DLI required up to 20psi
does that sound like it justifys each units replacement? I am learning but still not 100% on each components replacement.
Don't know the cam sensor type out of my head. The ECU Combines the three signals(as the tt has two cam sensors) and it looks kind of like this:
cam 1 ----|--------
cam 2 ---------|---
cps se -|-|-|-|-|-|-
I have the three signals combined in an scope read out from a member on here, i'll try to find it and will post it here.
With a dizzy i think there is no need for such a "sophisticated" system. :)
The na dizzy has 3 reluctor sensors NE, G1 and G2. NE reads 24 teeth (RPM - Effectively 12 crank teeth) and G1 and G2 both read a single tooth for phase calculations. G2 is a back up and also used for quicker starting.
The TT has a 12 pointed start, also a reluctor (NE), and two G1 and G2 (also both reluctors) in the head on the inlet cam. Same deal as the NA just different config. All the oil pump on the TT does is provide a position for the sensor to bolt to.
The VVTI uses a 36-2 on the crank and I think only one cam sensor as the gap on the crank wheel also act at a TDC reference. The cam sensor reads 3-1 which also allows the VVTi ecu to calculate the cam position relative the cam wheel.
Lyndon.
I've seen modified NA heads with a welded sensor, it's near impossible to be able to match another sensor in the correct place, so I wonder how they get 2 sensors that's required.
I always there there was a cam sensor, and a crank sensor. Now there is 2 cam sensors and 1 crack Im unsure how the NA conversion would locate a second cam sensor.
Think the best option is to go with the 7m gte and wastespark coils and run custom cams.
I've been talking to the guys at TTC about custom NA cams for a long time. It's definitely an option I may go down, it's just the importation of the cam's im worried about due to weight and cost, the cost to send them may kill me. It's around £500 to get your cams turned into anything you want, even 300 duration and 10mm+ lift.
Still go with a 7m cps though, dizzy looks sh*t. Good spot on the thread hunting :) :thumbs:
