Chris Wilson Posted February 28, 2012 Share Posted February 28, 2012 Available now: Uprated MKIV TT clutches. I use the stock, brand new driven plate, as it is correctly balanced, doesn't judder and will hold all but mega torque highly modded engines or cars used for drag racing. I modify a stock brand new cover to give more clamping force. The reason I tooled up to do these is some of the aftermarket US clutches I have fitted SEEM to be built from used cover assemblies with reground friction surfaces, and a stronger spring. I have had hellish trouble getting these to fully release, because due to this seemingly thinner cast iron friction face, the geometry of the clutch goes to pot, and being a pull type clutch (the hydraulics pull the bearing away from the engine, rather than the more normal push type) it is a lot harder to effect a cure. For 455 pounds plus VAT , you get a brand new driven plate, a brand new modded cover, and a brand new release bearing. I would rather fit myself so any complaints are down to me, I see a lot of clutches damaged by people without the right gear (a ramp and transmission jack, plus correct circlip tools and fitment) or clutches fitted to patently knackered flywheels. I will do a supply only if you feel competent to tackle the job or are using a bona fide garage to fit the clutch. Clutches damaged by incorrect fitment will NOT be considered for exchange, be SURE you or the garage know what's involved and have the right gear. Toyota use a dual mass flywheel (the flywheel is in 2 parts, an inner and outer assembly, damped in the middle) which is now showing signs of wear causing a lot of rattle when idling or on very light throttle openings. For God knows what reason they are charging about £400 + VAT for a new one, they look more like they should be over 500 to me, but don't say anything :-) The very similar LUK dual mass flywheel on Maseratis is nearly £1000 + VAT.... So if the flywheels old enough or abused enough to be scored, or it has movement beyond the Toyota workshop manual limits it should be replaced. Having me fit the clutch and / or flywheel will cost £175 + VAT labour. They are in stock now. Reply privately if interested please. [email protected] Thanks. Link to comment Share on other sites More sharing options...
Jamesy Posted February 28, 2012 Share Posted February 28, 2012 Really like the sound of these Chris and the labour cost is very good to fit for extra peace of mind Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 28, 2012 Author Share Posted February 28, 2012 Been doing these for years, let me know if you want one. Cheers. Link to comment Share on other sites More sharing options...
