RZ95 Posted February 28, 2012 Share Posted February 28, 2012 Sale pending.. It is time for me to pull the trigger.. I have other priorities in life right now and I need to free up some money. Someone will get a ridiculous deal on this one. Car has more than 3500 man hours of work in it & more than $200,000 USD invested.. The level of detail is through the roof.. Show stopper or Veyron killer, your pick. I don't think this car needs much introduction really, so onto the specs: Engine: 3.4L Stroker Bottom End: Titan stroker 3.4L crank Carrillo H beam rods, the new heavy duty version Custom Spec CP Pistons, CR=9.0:1 Custom uprated wrist pins ARP main studs ARP L19 head studs Titan Billet main caps PE bearings HKS 1.2mm metal head gasket Complete oiling system redone for optimum flow characteristics brand new 2JZ block, cryogenic treated for ultimate toughness, and no cement! Titan Stage 5+ Head: This was original a Titan stage 5 head, but further upgrades has been made to it, as seen below. The valve train has been swapped for cryo treated hardware, 1mm OS valves Dual springs CNC'd Shimless buckets GSC S2 cams (274 degree duration / 10.20mm lift) -------------------------------------------------------------------------------------------------------- Driveline: V160 w/ C's short shifter Tilton Quad plate carbon/carbon clutch Titan carbon Driveshaft (the big version) TRD differential (LSD) Cryogenic treated axles TRD transmission mount PHR solid engine mounts --------------------------------------------------------------------------------------------------------- Suspension: Powerhouse Racing adjustable control arms Powerhouse Racing adjustable toe links Powerhouse Racing adjustable traction links Titan Motorsports solid (billet) mounts thru out the entire susp. HKS Hipermax coilovers Cryogenic treated sway bars --------------------------------------------------------------------------------------------------------- Wheels/Tires/Brakes: Front brakes: Brembo 6 piston 14" Monoblock (slotted). Front wheels: CCW Classics 10x18" w/ black anodized centers, w/ Yokohama Advan A048 285/30R18 tires. Rear wheels: Weld Racing Alumastar 2.0 10x15", Anodized black centers, ARP 12-point bolts, Mickey Thompson ET Street Radials 325/50-15. Rear brakes: N/A rear brake callipers (coated Red), shim kit, Rotora drilled/slotted rotors, Project Mu pads. --------------------------------------------------------------------------------------------------------- Fuel Systems: Weldon 2345-A fuel pump Weldon inline 40m/10m filters Titan fuel rail Siemens Monotron 2430cc injectors Weldon Fuel Pressure Regulator Goodrigde G-line XF PFTE braided fuel lines Goodridge -AN fittings throughout --------------------------------------------------------------------------------------------------------- Ignition/Electronics: Motec M800 w/ 1MB logging, advanced features unlocked etc. JRR custom re-done engine harness JRR PnP Motec harness UTC adapter(USB-CAN) Motec CDI-8 ignition with Mil-Spec harness 4 stage map selection switch JRR 2-channel Traction Control / ABS signal converter kit Braille Carbon battery (All wiring and fuses is top of the line gold and platinum.. Alone worth more than $2000 USD) FJO Wideband O2 kit w/ NTK sensor Defi BF-Link boost Defi BF-Link EGT Defi BF-Link Fuel Pressure Defi BF-Link oil pressure Defi BF-Link oil temp. Defi BF-Link water temp. Defi control unit II --------------------------------------------------------------------------------------------------------- Turbo/Exhausting: Garrett GT47-88R (with custom divided exhaust housing A/R 1.18), HPC coated, & polished Full-Race T6 twinscroll manifold (newest version), HPC coated Full-Race 5" Down Pipe, HPC coated Full-Race 5" Mid pipe, HPC coated 2x Tial 44mm Wastegates, comes with a bunch of additional springs, for various settings. Full 5" SS cat-back exhaust, with Burns 5" muffler --------------------------------------------------------------------------------------------------------- Intake Manifold: *This is a custom unit from Virtual Works Racing, with 2x NX rails, Burst panel, etc.. Details below: 1x Titan fuel rail 2x NX rails 6x NX PIRANHA nozzles, (150hp & 225hp jets included) Braided lines from rails to nozzles 6x Monotron 220 lb injectors Pro-Flow Nitrous burst panel, w/ custom adaptor --------------------------------------------------------------------------------------------------------- Cooling: Virtual Works Racing 4" IC-to-TB pipe Virtual works Racing bar/plate FMIC (HUGE), with 4" in/ex ports Virtual works Racing 4/3.5" charge pipe (from turbo to FMIC) Fluidyne alu radiator, polished 2x Tial 50mm BOV's, polished Custom engine breather kit, sits behind the motor for a super clean appearance --------------------------------------------------------------------------------------------------------- Body work/Styling: Engine bay alone has hundreds of man hours in it! Stuff like PS resevoir, fusebox, battery, overflow resevoir, etc.. All been relocated or deleted. Custom roll cage Custom trunk Custom CNC'd mounts for stuff like fuel cells and Nitrous bottle Rear fenders have been widened about 1.5" on each side Antenna shaved/removed Toyota emblems shaved/removed License plate hole shaved/removed/relocated rear wiper shaved/removed sprinklers shaved/removed Side markers and blinkers shaved/relocated Facelifted tail lights Facelifted head lights Ganador mirros, with custom LED blinkers integrated Modified OEM bumper Modified RRM lip OEM side skirts Trial rear bumper/diffuser - blended into the car (done the RIGHT way, so it will last) Euro Spec aluminum bonnet Clear front indicators --------------------------------------------------------------------------------------------------------- Interior: As mentioned above, the entire interior is done by one of the top guys in Denmark. Everything is done in high-end Italian leather, too many details to list. This is a +$10,000 interior job. The finish is a dark red leather, with black leather details, and all black stitching. Other stuff to mention is: TRD steering wheel triple gauge A-pillar triple gauge glove compartment pod C's short shifter Pearl "Satin" coated dash & details Shaved dash for a clean look (relocated elements like lighter and stuff) Integrated control dash, for individual control (power) of EMS, CDI, gauges, map switch, etc. Plus a lot of small but unique details --------------------------------------------------------------------------------------------------------- Misc: There is A TON of small stuff and details that I haven't mentioned. Stuff like engine/bay details, Bling, custom modifications to the undercarriage, body, styling, etc.. I will of course take my time and go over all the details with the new owner, and provide him with all there is to know about this car. I will also assist with after-sales support to the extend he/she may request. 0-60mph in 3.19 sec. 100-150mph in 3.29 sec. 0-186mph in 11.43 sec. Street map is running 1,140 WHP @ 2.0 bar of boost (Vpower99 pump fuel). Stage 1 race map is running 1,354 WHP @ 2.5 bar of boost (Sunoco MAX NOS). KILL MODE is at 3.3 bar of boost + a 200 shot of direct port nitrous (shitload of power). Full boost is around 5000 RPM so it's fully streetable.. I haven't had the chance to run it in the quarter yet but it should be an easy mid 8 sec. car. This setup runs so smooth and everything is harmonic. Spools like no other T6 framed 2jz out there and is very easy to drive around town, although a bit loud. Videos: Pictures: http://www.bilgalleri.dk/uploads_xl_wm/2382215.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2344846.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2341688.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2341706.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2341687.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2349651.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2341689.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2341690.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2341691.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2341692.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2341693.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2341694.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2341695.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2341696.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2341697.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2341698.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2341702.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2341705.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2372116.jpg?09-11-2011_21:45:33 http://www.bilgalleri.dk/uploads_xl_wm/2372124.jpg?09-11-2011_21:45:33 Link to comment Share on other sites More sharing options...
Westy Posted February 28, 2012 Share Posted February 28, 2012 Very Nice Supra! Should sell on the continent no bother at that price, but very much doubt it'll ever see UK shores!? GLWS Link to comment Share on other sites More sharing options...
RZ95 Posted February 28, 2012 Author Share Posted February 28, 2012 Yeah you might be right. I hope some European members with money to spend will be reading this Link to comment Share on other sites More sharing options...
dan294 Posted February 28, 2012 Share Posted February 28, 2012 Awesome looking car and great price! Link to comment Share on other sites More sharing options...
marc_p Posted February 28, 2012 Share Posted February 28, 2012 Holy cr@p, that's a bargain! I really cannot see this staying for sale long. Link to comment Share on other sites More sharing options...
matt k Posted February 28, 2012 Share Posted February 28, 2012 Glws Link to comment Share on other sites More sharing options...
Josh Posted February 28, 2012 Share Posted February 28, 2012 That looks lovely! I was expecting a price of at least £50,000. GLWS Link to comment Share on other sites More sharing options...
supraturbochris Posted February 28, 2012 Share Posted February 28, 2012 Wow. stunning. only if i had the money. glwts Link to comment Share on other sites More sharing options...
supra-mike1984 Posted February 28, 2012 Share Posted February 28, 2012 Absolute beauty! GLWTS Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 28, 2012 Share Posted February 28, 2012 Thats to cheap! Link to comment Share on other sites More sharing options...
AndyT Posted February 28, 2012 Share Posted February 28, 2012 Gorgeous. Silly low price, but good luck for the sale. What's next for you then? Link to comment Share on other sites More sharing options...
Ricky49 Posted February 28, 2012 Share Posted February 28, 2012 Wasnt this KDW's car the best supra that has ever graced the planet. Link to comment Share on other sites More sharing options...
tony tt Posted February 28, 2012 Share Posted February 28, 2012 Wasnt this KDW's car the best supra that has ever graced the planet. The very one I'm sure. Link to comment Share on other sites More sharing options...
Jamesy Posted February 28, 2012 Share Posted February 28, 2012 Wasnt this KDW's car the best supra that has ever graced the planet. knew i recognised it!!!! ... is this still KDW? Link to comment Share on other sites More sharing options...
JakeG Posted February 28, 2012 Share Posted February 28, 2012 That is stunning, glws Link to comment Share on other sites More sharing options...
Supra Gaz Posted February 28, 2012 Share Posted February 28, 2012 VERY impressive. A thoroughly done job. Glws, I can see this swabning off somewhere abroad pretty quickly. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted February 28, 2012 Share Posted February 28, 2012 yes its KDW but give the guy a break lol.. nice supra mate and great price. Link to comment Share on other sites More sharing options...
suprasize Posted February 28, 2012 Share Posted February 28, 2012 perfection Link to comment Share on other sites More sharing options...
Dan_Turism0 Posted February 28, 2012 Share Posted February 28, 2012 if my numbers come up this Friday i'll be buying this, absolutely perfect! Link to comment Share on other sites More sharing options...
Wez Posted February 28, 2012 Share Posted February 28, 2012 Very nice, any chance you can post up the dyno plots to go with each power output on different fuels? Link to comment Share on other sites More sharing options...
JamieP Posted February 28, 2012 Share Posted February 28, 2012 To cheap, absolute bargain. Link to comment Share on other sites More sharing options...
Littler Posted February 28, 2012 Share Posted February 28, 2012 Christ what a car! Don't think this will hang about! I like how it has a 'kill mode' Link to comment Share on other sites More sharing options...
RZ95 Posted February 28, 2012 Author Share Posted February 28, 2012 This is the first place I have officially announced this price. I didn't want to go public with this price because it really is too low. I was hoping to move it through my personal network under the radar, but I need it gone so here it is Link to comment Share on other sites More sharing options...
jimojameso Posted February 28, 2012 Share Posted February 28, 2012 Absolute steal!! If i had the money would be all over it!! Link to comment Share on other sites More sharing options...
hodge Posted February 28, 2012 Share Posted February 28, 2012 I'm Sure Jurgen could sell this in a shot Kim. May be worth dropping him a email or p.m. As said its way way too cheap for what it is. If I were to sell mine I'd advertise it for a couple of grand more than this. If your not desperate to sell I'd reconsider your price for sure. Link to comment Share on other sites More sharing options...
