Turbo gasket/ skim
antno
We never ever use a gasket, make sure both faces are faced up and fit with no gasket. Never seen any gasket last without leaking.[/
Cheers
Would you blue the faces and check the contact area?
We check them with a proper straight edge, if they are not perfect we have them machined, both faces MUST be perfectly flat, you want the maximum contact area, the last T4 turbo we did with a gasket (the apprentice fitted it) lasted 40 miles and the turbo was torqued down etc, we removed the gasket and never had a problem.
Cheers Pal. I'll give it a go. Ive heard a few people running without gaskets but never tried it myself
