RZtwin Posted February 27, 2012 Share Posted February 27, 2012 I have a 93.5 JDM Supra RZ TT hardtop. I'm not certain if it is LSD or not but I can tell you when I do a burn out that both tires leave tread marks Can someone give me a few options on what the best oil would be to go into my diff? Thank You Link to comment Share on other sites More sharing options...
sdistc Posted February 27, 2012 Share Posted February 27, 2012 I've just put some Castrol Syntrax Limited Slip 75W-140 into my TRD diff. Royal Purple has also been recommended on SF.com. Link to comment Share on other sites More sharing options...
mellonman Posted February 28, 2012 Share Posted February 28, 2012 i asked this very same questio last night in the correct thread have a look http://mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine Link to comment Share on other sites More sharing options...
bodilx6 Posted February 28, 2012 Share Posted February 28, 2012 Check the link above for fluid and check your VIN plate for diff info. From http://mkiv.supras.org.nz AXLE Example Description Crown Wheel Size A A (8'' - 200mm), B (8.7'' - 220mm) Differential Ratio 01 01 (4.083:1), 02 (3.769:1), 03 (3.267:1), 04 (3.538:1), 05 (4.083:1) Differential Type A A (Standard open differential), B (Torsen LSD), D (Torsen LSD) Link to comment Share on other sites More sharing options...
RZtwin Posted February 28, 2012 Author Share Posted February 28, 2012 Thanks guys Link to comment Share on other sites More sharing options...
Dim Sum Posted February 29, 2012 Share Posted February 29, 2012 I used Silkolene BOA 90 LS High Performance Gear And Limited Slip Differential Oil Heres the link for it http://www.opieoils.co.uk/product-finder/car/engine-oil/toyota/1997/supra/PETROL/supra/32847/product-finder-2.aspx if not sure give them a call, they are very helpful. Link to comment Share on other sites More sharing options...
CJ Posted February 29, 2012 Share Posted February 29, 2012 Wynn you get your oil, buy a new keyboard too as the ? Key seems to be stuck on! Link to comment Share on other sites More sharing options...
