Chris Wilson Posted February 27, 2012 Share Posted February 27, 2012 I have a Netgear router connecting two PC's and a ethernet over mains adaptor to the phone line and internet. I also connect a printer to one of the sockets. It is now using all its sockets and I want to add another PC and two more printers. I have acquired (thanks IanC) an old DLink DES1008 10/100 fast ethernet switch with 8 ports on it. can I connect the "input" port of the DES1008 to one of the "output" ports of the Netgear router, thus adding seven more ports? Is it as simple as that? Cheers. Link to comment Share on other sites More sharing options...
Chucky_waR Posted February 27, 2012 Share Posted February 27, 2012 Hi Chris.. that should be all.. Run the out port from your router to the in port on your switch.. you should not need to config anything Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 27, 2012 Author Share Posted February 27, 2012 OK. Thanks, will wire this up tonight, cheers. Link to comment Share on other sites More sharing options...
Scott Posted February 27, 2012 Share Posted February 27, 2012 This is exactly how it works Chris. Make sure you put the likes of the printers onto the switch rather than a PC you want to use. Switches will slow things down a tiny little bit if using more than one port on it at the same time (as it switches back and forth). Link to comment Share on other sites More sharing options...
MaveriK Posted February 27, 2012 Share Posted February 27, 2012 I would venture you may need a cross over cable as you are going like for like unless the active kit supports MDI/MDI-X Link to comment Share on other sites More sharing options...
Thorin Posted February 27, 2012 Share Posted February 27, 2012 It supports auto-negotiation so any old network cable will be fine. Link to comment Share on other sites More sharing options...
