High boost with AVCR switched off
Neil Sandham
Guys,
Over the past two years when ever I switched my AVCR off (when the g/f is driving!) the most boost the car would make was 0.8kg/cm2. That was just with CW pipes and a Super Drager.
Over the past few days however, I noticed that it's producing 1.01 kg/cm2 with it switched off.
any ideas?
Actuator pipe split ? :(
Engine finally "run in" loosend up after 105,000 miles? :p
oh btw can anyone remember the converison factor for kg/cm2 to PSI ??
cheers
Neil
Originally posted by Ashley Willis
F*cking hell, Im hitting 20psi.......
Ash , yours a J spec ?
They often do coz the cats helped control boost creep due to a smaller wastegate.
I've never heard of a UK spec getting above 12psi even with exhaust and down pipes unless a boost controller is fitted.
cheers
Neil.
