Chris Wilson Posted June 15, 2012 Share Posted June 15, 2012 what was wrong with his old engine ? Low on oil, like cars with full ashtrays, Keron just changes them, he doesn't muck about Link to comment Share on other sites More sharing options...
keron Posted June 15, 2012 Share Posted June 15, 2012 headgasket... i think the initial problem was caused from a water hose to the bulkhead. toyota crap clip must have lost its strengh and was leaking under pressure. i think it must have lost its coolant over time as fitz didnt check the water levels.... thing is you would not have seen it drip etc as soon as it leaked out, it touches the metal hot pipe and evaporates so not too obvious.... Link to comment Share on other sites More sharing options...
Dnk Posted June 15, 2012 Share Posted June 15, 2012 low on oil, like cars with full ashtrays, keron just changes them, he doesn't muck about Link to comment Share on other sites More sharing options...
keron Posted June 15, 2012 Share Posted June 15, 2012 quicker and easier to swap the engine over! by the time you strip one down to inspect, then could find a problem with the head etc...waste of time....i have a couple of na engine in stock i know are perfect so makes sense to swap it out... Link to comment Share on other sites More sharing options...
Dnk Posted June 15, 2012 Share Posted June 15, 2012 headgasket... i think the initial problem was caused from a water hose to the bulkhead. toyota crap clip must have lost its strengh and was leaking under pressure. i think it must have lost its coolant over time as fitz didnt check the water levels.... thing is you would not have seen it drip etc as soon as it leaked out, it touches the metal hot pipe and evaporates so not too obvious.... Pretty much what i thought seeing as it had overheated properly on more than 1 occaision Link to comment Share on other sites More sharing options...
Fitz Posted June 15, 2012 Author Share Posted June 15, 2012 Runs like a dream again As Keron stated, I had a new engine put in to save the hassle. It wasn't financially viable or time friendly to have the head stripped down, skimmed (if within tolerence) etc etc. Link to comment Share on other sites More sharing options...
Guest Budz86 Posted June 16, 2012 Share Posted June 16, 2012 Runs like a dream again Glad to hear it mate, fancy a run at the pod? Link to comment Share on other sites More sharing options...
Fitz Posted June 16, 2012 Author Share Posted June 16, 2012 Taking on a TT.... I don't mind Link to comment Share on other sites More sharing options...
Abz Posted June 16, 2012 Share Posted June 16, 2012 Dean I'll have you as well! Link to comment Share on other sites More sharing options...
Guest Budz86 Posted June 17, 2012 Share Posted June 17, 2012 I better bloody win after all this! Don't want to be known as the new club 'Abz!' Link to comment Share on other sites More sharing options...
